I have a problem that i not can resolve, i have a run a new firmware update for the Plugwise network.
But after all the circles are restart the complete network is down.
When i restart the source software i see that the software have found the USB stick but can not anymore find the modules, even the function for "insert modules" can i not use anymore (the button is grey)
what can i do to solve the problem without reset the complete network?
I like to hear it.
Plugwise modules down?
__________________
Re: Plugwise modules down?
Try running the config wizard?
That have do the trick, I should have known this
Only I'm just getting a new challenge in the return from the software.
Somthing with a serial port that is closed, at this moment i'm in touch with plugwise to solve this problem because it's since the last update 2.17
__________________
