Hello everyone,
I am using the Sense temperature and humidity sensor from Plugwise.
In the Plugwise Source program (v2.21) I can read these 2 values and they are nicely updated and displaye graphically
However when I want to access these 2 values from the webserver, the fields turn out to be empty.
Does any one have experience with these sensors?
The webscript I use is the following:
$list=Plugwise.Modules
ForEach $list
<% If $list[$_Index] != null %>
"<%=$list[$_Index].Name%>",
<%=$list[$_Index].LastSeenDate%>,
<% if ($list[$_Index].Name == "C....") || ($list[$_Index].Name == "C...")
Temp = <% $list[$_Index].Temperature %>
Hum = <% $list[$_Index].Humidity %>
<%/If
<%Else%>
<%/If
<br>
/Foreach
accessing sensor values from Plugwise Sense
Re: accessing sensor values from Plugwise Sense
It is not yet supported in the webserver AFAIK.
Thought this was mentioned in the release notes of Source.
Nico - Domotica in de Betuwe
It works as advertised for me with Source 2.21. I put it into some debugging XML with the following template code:
<?xml version="1.0" encoding="iso-8859-1" standalone="yes"?>
<modules>
foreach Plugwise.Modules
<module>
<appliance><%=.Appliance%></appliance>
<humidity><%=.Humidity%></humidity>
<lastCompletedLogIndex><%=.LastCompletedLogIndex%></lastCompletedLogIndex>
<lastSeenDate><%=.LastSeenDate%></lastSeenDate>
<lastSeenSeconds><%=.LastSeenSeconds%></lastSeenSeconds>
<macAddress><%=.MacAddress%></macAddress>
<name><%=.Name%></name>
<status><%=.Status%></status>
<temperature><%=.Temperature%></temperature>
</module>
/foreach
</modules>
For me too:
<% foreach Plugwise.Modules %>
<% If (.Type == 5) %>
<sense>
<moduleid><%=.Id%></moduleid>
<macaddr><%=.MacAddress%></macaddr>
<typetext><%=.TypeText%></typetext>
<image><%=Plugwise.ImagesPath%>32/<%=.StatusImageName%>.png</image>
<online><%=.IsOnline%></online>
<lastseen><%=.LastSeenSeconds%></lastseen>
<firmwaredate><%=.FirmwareDate%></firmwaredate>
<firmwareversion><%=.FirmwareVersion%></firmwareversion>
<hardwareversion><%=.HardwareVersion%></hardwareversion>
</sense>
<% /if %>
<% /foreach %>
