could be...
i checked it:
============== 1 packet ==============
Request.php:204 :: Good sendstring (without checksum):
0012000D6F0000D3198D (20)
Request.php:211 :: Generated Decimal CRC
446 (3)
Request.php:212 :: CRC decimal to Hex
1be (3)
combined send string:
0012000D6F0000D3198D1BE (23)
"response from ..... (plug?) ":
0000000000C264DF
============== 2 packet ==============
0026000D6F0000D3198D(20)
16964(5)
4244(4)
0026000D6F0000D3198D4244 (24)
Response from plug:
002700DD000D6F0000D3198D3F7D709BB612A7853C62D7FA00000000BA4C
This shows that the first dec-crc is also to short.
The first combined packet/string is wrong and the plug doesn't response.
The second combined packet/string is goed and the plug does response.
[/edit]
based on the following python script, i changed the checksum function:
python-plugwise / plugwise / protocol.py
look at lines:19, 157, 161
i made the following python script:
#!/usr/bin/env python
import sys,struct,crcmod
# If no arguments were given, print a helpful message
if len(sys.argv)==1:
print 'Usage: dec'
sys.exit(0)
crc_func = crcmod.mkCrcFun(0x11021, rev=False, initCrc=0x0000, xorOut=0x0000)
print crc_func(sys.argv[1])
in php i change the code to:
// $string = $sendstring;
$crc = exec("/home/marco/crcfun.py ".$string."");
return dechex($crc);
this gives the following result:
446 (3)
1be (3)
0000000000C264DF
16964(5)
4244(4)
Response from plug:
yes,yes it is copied from above, because the python script gives exactly the same result.
Both script generate a short decimal CRC....
for those how want to play,check,debug,etc... the mac address of the plug is D3198D and i'm trying to receive the current power usage.
[/edit]
[edit2]
oke i found the following site:
crc-calculation
On this site you can generate multiple CRC on a string.
based on the driver i expect a "fc0a" CRC for "0012000D6F0000C3A6FC".
When i generate the ASCii CRC's i indeed see "CRC-CCITT (XModem) 0x
FC0A"
when i generate the ASCII CRC's for "0012000D6F0000C3A6FC" i get:
1 byte checksum 48
CRC-16 0xB2A7
CRC-16 (Modbus) 0xA983
CRC-16 (Sick) 0x1CFD
CRC-CCITT (XModem) 0x01BE
CRC-CCITT (0xFFFF) 0xF706
CRC-CCITT (0x1D0F) 0x9E0A
CRC-CCITT (Kermit) 0x2A5A
CRC-DNP 0xAA6D
CRC-32 0x83C31987
01BE
So it look likes that Digit had it all right!!
Probably the dechex() php function is missing the whole thing up....
The question now is, how can i solve this problem?!
[/edit2]
[edit3]
change Python to:
print str('%.4x' % crc_func(sys.argv[1]))
and....
IT WORKS!!!!!!!
the dechex() function from PHP messes the whole thing up.
anybody a native php fix?
[/edit3]
