Power-on state after power loss
jeroenc
Post by jeroenc »
I've noticed a couple of times after (self-induced, ground fault ;)) power interruptions that the circles come on line in a power-on state. Plugwise confirmed this was the default behaviour, and they are unwilling to make the startup behaviour configurable.
They mentioned implementing a scheme or script, but these would need to send commands to the circle continuously (and I don't know how scripting works).
Did anybody else "suffer" from this and has come up with a solution?
Regards, Jeroen
erikk
Re: Power-on state after power loss
Post by erikk »
Put them behind a UPS ;)
PietjeNL
Post by PietjeNL »
High standby killer as a schedule will put the circle off when it goes on.
jeroenc
Post by jeroenc »
Thanks Pietje,
unfurtunately that won't work.
I use the circle for irrigation, which can be on for hours. The standby scheme would turn it off again. I switch this manually switched via my iPhone, which unfortunately doesn't register in the Source app or script.
I was on the phone with Plugwise today (they are always very knowledgable and helpfull). He said somebody used one circle specifically and only to detect power outages. Then via a script he switches the "usually off" circles.
Quick and dirty, but it does the job!
So now it's on to learning scripting, unfortunately I don't have time coming months...
Regards, Jeroen
Bjochems
Post by Bjochems »
I have implemented the solution with the extra plug. When you use Homeseer it's pretty easy to implement this.
Bas
Dowser
Post by Dowser »
Combine the outage-detection with a change in your procedure.
Instead of changing the switch directly from you iPhone, chage it from your iPhone, but through a script that saves the intended state in a file. Then you can verify if the switch is on when it should be on or off when it should be off.
(And correct any mistakes.)
//Markus
jeroenc
Post by jeroenc »
Dowser: check!
Bjochems: tnx, but I don't have homeseeer...
Return to “Plugwise Forum”
