Just made my plugwise webpage better
Quart
Post by Quart »
Hi
Just want to show you what can be done with some php code and the plugwise webserver.
WIth at friend of mine at http://www.lokaltvader.se we have made this.
If you come from a "trusted" ip you can turn aplliances on/off
Here is a link if you want to download it: http://www.sundshult.se/temp/pw.zip
We also have some scripts checking if some appliances is taking more then example 40W and then they turn on/off someother things.
We am also using the sunmeter from my Davis station to trigger lights at home when its getting dark.
http://www.sundshult.se/wxpw.php
Re: Just made my plugwise page better
Nice!
vanisher
Post by vanisher »
Nice!! Are you going to publish the php scripts?
Wim2008
Post by Wim2008 »
More people are interessed in the script.
BR Wim :wink:
Wim2008
Post by Wim2008 »
You make us curious.
hansieh
Post by hansieh »
That looks good,
I'am also interested in the scripts,
Hans
(domotica, arduino, MySQL, PHP, electronics)
http://www.chamiri.nl
Quart
Post by Quart »
Thanks for all credits.
I dont want to support them but I will try help you all get it going.
But they are build round plugwise own ´webserver and it can get inputs from Weather-Display software.
I will put them all in a zip package and will post a link.
vanisher
Post by vanisher »
Hi Quart,
Did you have time yet to 'zip-up' the package?
Quart
Post by Quart »
yjb
Post by yjb »
Quart wrote:Finally, here it is.
Thanks so much! Let's see if I can find some time to play with this.
Ysbrand
Wim2008
Re: Just made my plugwise webpage better
Post by Wim2008 »
Thanks for sharing this script.
Can you give a short explanation, what to do with those 3 files?
B.R. Wim :wink:
Quart
Post by Quart »
Put them all in example a folder called pw
then edit the file pwsettings.php, all things you need to edit is explained in pwsettings.php
After the you just open a webbrowser and go to your website example http://www.mysite.se/pw/index.php
Just added a scriptfile I am running each 5 minutes everyday, it checks the sunlight measured with my Davis VP station.
Right now I am using 9W as limit, when it goes under 9W it send a "turn on" command to my "lamps group" in Plugwise
The script can med downloaded here http://www.lokaltvader.se/download/autoswitch.php
Wim2008
Post by Wim2008 »
Thanks. I will give it a try.
BR Wim :)
MarnixT
Post by MarnixT »
THanks for the scripts. I did try a little with the xampp webserver after which a nice page showed up, however with errors like
Notice: Use of undefined constant mac - assumed 'mac' in C:\NODOWeb\htdocs\index.php on line 157
Notice: Use of undefined constant lock - assumed 'lock' in C:\NODOWeb\htdocs\index.php on line 158
after this I realised it was supposed to work with the inbuilt webserver.
Unfortunately running that I got back a plain text page, starting with
<?php
require_once('pwsettings.php');
etc.
What can I do about this?
Quart
Post by Quart »
You shall not use the Plugwise webserver, I dont think it can execute PHP pages.
So you can use xampp but you need to edit the pwsettings.php and tell whre your plugwise webserver is etc
Return to “Plugwise Forum”
