plugwise stick on remote location
labium
Post by labium »
i am trying to communicate with a plugwise stick over the internet on a remote location. I use a spider gadgeteeer board with a usbhost to put the stick in , a serial port to connect to a digi serial port server.
the digi realport com port on the computer with the plugwise source program, isnt scanned by the plugwise source , i think because it isnt a ftdi virtual port. i see when the source starts it sends a packet to each ftdi serial port but not to digi realports or prolific virtual ports.
is there an easy way to disguise a virtual comport not from ftdi to a ftdi virtual com port ?
Akatar
Re: plugwise stick on remote location
Post by Akatar »
try:
setup stick, circle+ and circles local.
plugwise source knows you're stick and circels now, move stick and circes to remote location and insert comport into plugwise config:
settings.ini:
comport=com11 (depends on you're comport)
labium
Post by labium »
where can i find that file ?
Akatar
Post by Akatar »
you can find it or create it in youre plugwise\plugwise source folder
if you don't have it, create the ini file
labium
Post by labium »
thank you very much Akatar , it works :D i added the file settings.ini with one sentence : comport=com1
Akatar
Post by Akatar »
great, thanks for the feedback
labium
Post by labium »
does someone know how to define 2 comports for the stick in settings.ini of plugwise ?
with one comport it is
comport=com5
Akatar
Post by Akatar »
you need a multiple network license.
then just add a second comport in the ini file
labium
Post by labium »
i am allowed for two sticks
ini:
comport=com5
comport=com15 ?
Akatar
Post by Akatar »
thats correct,
first add the stick in the source with plugwiseconfig.
add the second stick etc etc
my settings.ini
comport=com11
comport="ssh://stretch:str821@192.168.1.132:22|ttyUSB0"
labium
Post by labium »
yes it works, thank you again akatar, i have now a stick in my christmass home added to my home network. if it keeps stable i will reveill the solution on this forum , i have my stick remote on a fez spider which is connected to a digi serial port server for a tcp connection to my home.
Return to “Plugwise Forum”
