Source is running fine and recognises the stick without problems but when I try to enable the webserver it shows the status as 'Access is denied'. The only process active in the taskmanager is PlugwisePC.
If I run the ServerProgram it lists as 'running' but I can't connect to the given url.
Taskmanager lists nothing besides the SourceServer therefore think the process needed for the server is not running.
The licence features do list the webserver thus I haven't got a clue as to why it is not working.
Anybody?
source 2.22 webserver 'access is denied'
Re: source 2.22 webserver 'access is denied'
After some more troubleshooting and comparing my old winXP setup with the new win8 VM I managed to track this down to the UserAccountControl.
Now I have all shortcuts to AND all exe-files in the Plugwise program folder set to 'Run as Administrator' and it works.
Nico - Domotica in de Betuwe
Great ! That finally solved my problem. I have another program running that listens to port 8080, which is the default for Plugwise, and when I tried to change that port I also got that message "Access is denied". Plugwise support was a disaster, after only one reply stating that "something must be running on your computer" they didn't reply on any other email.
Now I applied the "run as adminstrator" as you mention and it works fine.
Thanks for the hint !!
Soitjes.
Soitjes.
My Digital Home Server - http://www.digitalhomeserver.net
