version 2.23.13000420
Downloaded today from http://www.myplugwise.com
Fortunately the installation created a system-restore point which, for the first time in my life, helped me.
After the system-restore I only had to copy the old database .mdb and the old release is now running again..
(I backup the plugwise database .mdb every day
Still would love to know why this happened and if it can be fixed. (even though I'm not to sure if I need to upgrade reading through some of forum messages)
New Source 2.23 (20130301.0) release!
Re: New Source 2.23 (20130301.0) release!
Normal fix is to run config wizard again, had the same problem and the helpdesk gave me that as a solution and it worked.
Does anybody still have this 20130301.* setup file?
I would like to receive it, because I can only find the 201304* versions.
someone stil a solution for the node limit of 25 ?
or is it posible to go back to the older version?
i use sourse now from 2009,... and dissapoited that this update has suddenly a restriction in it
installed the source version from the plugwise site,...looks that i can install modules again
looks like my problem is solved
