Source v2.23 crashing after restart
pvgent
Post by pvgent »
Today, i did a reboot of the PC which is running Source. In programs i set the option to create a backup at startup every day.
After the backup, the Source wouldn't start, i got the 'object reference not set to an instance of an object' error. I did a restore of a previous backup with no success. When i restored a backup of a 2.22 Source backup, the Source started with the 'license' message and everything is Ok.
I also saw a difference in the backup in Source and the one in Start -> All programs -> Plugwise Source. The backup in Source doesn't close the Source, the backup/restore from Start -> All programs -> Plugwise Source closes and start Source.
If you make a backup with backup/restore from Start -> All programs -> Plugwise Source the Source will not start after the backup.
If you make a backup with backup in Source, Source keeps running Ok.
If you restore a backup made with Source v2.23, the Source will not start.
If i stop/start Source v2.23, it get the 'object reference not set to an instance of an object' error. Only remedy is Restore backup Source v2.22 backup
What's wrong, why didn't the beta testers find this bug.
RdP
Re: Source v2.23 crashing after restart
Post by RdP »
I have exactly the same problem, so this must be a bug in the source software.
/Rien
Darwusch
Post by Darwusch »
Yes, me too. Same problem, as described in the intro thread of source 2.23.
I sent an email to plugwise but I'm still waiting for an answer.
Darwusch
pvgent
Post by pvgent »
I also sent a email.
And now we wait :)
pvgent
Post by pvgent »
Still no answer from PlugWise Helpdesk.
Unfortunaly i don't have a backup of the Source v2.22 exe, thus every time i want to start Source i have to restore a backup from pre v2.23
On the PlugWise site you can only download v2.23
Darwusch
Post by Darwusch »
I still have a setup file for v2.22.
You can pm me an email address then I'll send it to you.
Verkenner
Source v2.23 working fine
Post by Verkenner »
Source v2.23 ( 20130301.5 ) is working fine here.
No problems at all.
Cheers
Best regards, Verkenner
pvgent
Post by pvgent »
How many modules do you use?
Do you use the build in Webserver?
Does Source make a backup at startup?
RdP
Post by RdP »
Problem solved.
Go to http://www.myplugwise.com and download the latest version ((20130301.5)
pvgent
Post by pvgent »
Source doesn't see an Update.
Downloaded 20130301.5 from Plugwise site. Installed and Source started without problems, it also made a backup on startup.
To bad there is no info about what the problem was, i also haven't heard from the Plugwise Helpdesk.
I'm happy that Source (and web server) are running again, we are depending more and more on this kind of software.
Return to “Plugwise Forum”
