new installation. Data alsways showing 0 watt
Noel
Post by Noel »
Due to a bad HDD I needed to reinstall the server.
Doing so I also installed the new Source 2.23(2130901.2).
Now for some reason all Plugs are showing 0 watt as usage. (ON/OFF is working fine)
Could it be that the firmware in my plugs is to old? (t's version 2008-08-26)
if so, where do I download the latest firmware, and how do I update the plugs with it?
Thank you
RdP
Re: new installation. Data alsways showing 0 watt
Post by RdP »
Start the upgrade wizzard of the Plugwise software.
/Rien
Noel
Post by Noel »
Great..
Het voorberieden is mislukt bij 1 of meerdere modules.
Voor het optimaal functionere van uw plugwise netwerk dienen modules van het zelfde type dezelfde firmware te hebben.
The Stick has firmware 2008-03-10. The plugs are using: 2008-08-26
Only options available after the message: Afbreken, Opnieuw and Negeren
When I press "Negeren" the update wizard exits.
Akatar
Post by Akatar »
there is a change you need an older version of the source
Noel
Post by Noel »
Sounds logical.
Anyone here with an "old" version of Source for me that "might" work?
raymonvdm
Post by raymonvdm »
I got 2.22 for you
p.s. I`m using firmware 27-06-2011
PietjeNL
Post by PietjeNL »
Its easy when u know how to :)
From HD email :)
Download and install Source 2.17 from http://myplugwise.com/source/pwsetup_2.17.exe
Install the set and click update from Source (this way the Source doesnt update first)
Then the update wizard starts and will update the modules.
Then u can go to the release version of Source and all should work.
Noel
Post by Noel »
Thank you all,
Plugs are updated and the latest source is working fine for me :-)
Return to “Plugwise Forum”
