I recently started with a little website showing data from my weather station and solar panel production. Since I already owned a smile I tried to get data from it via the plugwise webserver.
I get the xml with al appliances http://192.168.x.x:8080/api/data.xml?type=appliances.
I can read the values from my power meter <powerusageround>650 W</powerusageround> however this value is always positive even when source and plugwise iphoneapp show negative values.
Is there another way to show wether the power usage is negative?
Remco
Plugwise webserver smartmeter production shows as consumptio
Re: Plugwise webserver smartmeter production shows as consumptio
I would like also to include some of the readings I have on my Plugwise web server on my Solar web site. Also have a Weather station, but only uploading to wunderground site.
What I've included on my solar website, is a cumsuption reading directly from an Energy device "Theowl". So I can have a reading from Consuption versus prodution.
Sorry I cannot answer your questions direclty, but I really want to know how are you including the weather readings on your website?
For the weather station i use http://sandaysoft.com/products/cumulus
This software gets the data directly from my Davis Vantage Pro 2 console and sends the data to wunderground and publishes to my website every 5 minutes and tweets every hour.
I just use the standard templates which look like this: http://weather.vanbreugel.org.
I use the same: http://members.casema.nl/joop.kunst.
It is easy to add your own stuff to it.
I added a sunny indicator, a picture and info from buienradar.
Sent from my Nexus 7 using Tapatalk 4
