Is it possible to use the kaku built in switch with a ( wisselschakeling ). And if yes , how?
Thanks, edwin
How Wisselschakeling Hotelswitch
Hi Edwin,
I think you mean the AWMR-210 or AWMR-230? You should be able to use it in a 'wisselschakeling'. The unit switches based on change between the connection state of the two switch wires.
Bart
Bart
- Snelvuur
isn't "wisselschakeling" not "hotel" switching? (only with hotel its mostly 3 switches, instead of 2)
- b_weijenberg
- Fantic
Hotelschakeling is with 2 'wissel' switches and can be extended with 1 or more cross switch when you need more switching points, these cross switches go in between the 2 lines of Bert's beautiful drawing.
Thank's for the drawing i see now that it's no problem to make it.
Thank u all for helping me
Is this possible/allowed ?
Nope...
Tried this recently, but resulted in strange behaviour and finally a defective dimmer. I replaced the switch by a "dubbele wisselschakelaar" such that the input lines are both separated and now it is working fine.
That's not the issue.
I already have a "dubbele wisselschakelaar", one switch for the lamp in the hall and the other lightswitch is for above the stairs
There 5 wires to this switch.
1 fase (feeds both switches)
2 black ones to the other "dubbele wisselschakelaar" in the hall
2 black ones to the switch upstarts
Sadly there is no space for 6 wires and i really want to use my original jung AS500 "dubbele wisselschakelaar" switch
I run into problems after linking input lines to eachother (see drawing what caused the problem). I also tried various combinations without success.
