KAKU starter kit APA2-2300R
Forum about Click On Click Off (KAKU), Home Easy and related hardware.
Jeroen Bartels
Post by Jeroen Bartels »
I bought a new click on click off (COCO?) starterkit with automatic house code (the old starterset had only ABCD/123). the small remote that is supplied is recognized by RF receiver as Home Easy.....
I know Home easy en COCO do not go well together but this is only on the transmitter side right? For these modules I'm planning to use RFXcom Xmitter only so this should not be a problem I hope?
**Jeroen**
Louis
Re: KAKU starter kit APA2-2300R
Post by Louis »
HS with RfxCom Xmitter can control these devices (use rfxcom outputdevice ACmodule), no problem.
If you do not use the remote to control the devices directly, then you can use the remote to trigger other events in HS.
Return to “Click On Click Off & Home Easy”
