KaKu and Duwi Funk
Forum about Click On Click Off (KAKU), Home Easy and related hardware.
William.abbo
KaKu and Duwi Funk
Post by William.abbo »
Does anyone know if the KaKu modules and Duwi Funk modules are compatible ie. use the same protocol. So, can I control a Kaku receiver with a Duwi Funk module without the use of HomeSeer and RFXcom?
Weet iemand of de Kaku modules en Duwi Funk modules compatible zijn met elkaar, m.a.w. kan ik met een Duwi Funk zender een KaKu-ontvanger sturen ?? Dit alles zonder tussenkomst van HomeSeer en RFXcom?
martinisoft
Re: KaKu and Duwi Funk
Post by martinisoft »
Düwi Funk is based on the Z-wave standard.
This is completely differend from Kaku.
Z-wave uses an other (les crouded) frequency to opperate, and is secure by design, wich Kaku is not.
So those two types of devices cannot directly interact with each other.
kind regards..
Martijn.
William.abbo
Martijn,
I was not talking about Duwi Z-Wave but about Duwi Funk-modules, they are completely different. Duwi Funk-modules is something completely different then Duwi Z-Wave
GertBeckers
Post by GertBeckers »
Did anybody test the compatibility of KaKu? Do we know which are the compatible products / ranges?
Gert
Return to “Click On Click Off & Home Easy”
