Plugwise Homeseer Plugin
Installing...
Rene,
Thanks for the plugin
All is working fine. Including the actual usage
Now going to change my events for usage based triggering.
Rene,
The auto created devices are missing some options in HSTouch.
In HSTouch there is no option for toggle on/off
I think this has to do with the device type
The buttons are created using the standard api functions. I do not have and use the HSTouch software so it will be hard to figure out what is causing the problem.
@Chak: The device used is a IOTYPE_CONTROL as defined in the SDK. I do not think I have any choice there, cause it is no X10 device. Maybe you should ask Homeseer which device types are supported by the toggle option. From the Homeseer forum I understand other people have the same problems with some of their devices.
So Rene,
If I read this correct, Source still needs to be running to make this work?
Yep, that's correct. First get things going this way and then I will connect to the plugs directly.
Can someone post some screenshots ???
Thanks...
Thanks...
It does not look that different from DJ's scripts:
thanks for this plugin.
this plugins use ' for the plugwise. so '1 '2 etc.
when i restart home seer i get an error
13-12-2008 13:44:07 - Plugwise - ERROR: Database query failed: Syntaxisfout (operator ontbreekt) in query-expressie HSDevice = ''4'.
when i had the ' as rfxcom devices it was errors everywhere, perhaps this plugin uses ' creates errors in homeseer (scripts?)
The plugin requests homeseer for a unique house code. This means the ' as house code comes from homeseer. Probably I have to escape this house code before writing to the database. When I have some time, probably tomorrow, I will look into this. Thanks for mentioning the bug!
the source is working, server is up. got the next error when i try to switch a device on/off homeseerand plugwise are on the same server
13-12-2008 14:31:33 Plugwise ERROR: Cannot set state of appliance (ERROR: De externe server heeft een fout geretourneerd: (404) Niet gevonden.)
gr Ruud
And thanks for this great plugin
gr Ruud
Rene,
For mobile access I use Rover plugin.
http://rover-for-homeseer.blogspot.com/ ... lcome.html
All the device have double control buttons for turning on/off
[img]uploaded/Chak/20081213143810_rover.gif[/img]
@rualblas: Looks like you didn't copy the switch.html file in the www directory of Plugwise.
@Chak: So you have a choice;-) I will look into it tomorrow. Very strange though, I only used SDK features to add the buttons.
