Kaku not showing up in homeseer
Snelvuur
Post by Snelvuur »
I assume its something simple but i cant seem to put my finger on it.
Have one of those kaku door bells. When it rings i get:
19-4-2012 17:49:28 - RFXCOM - (RecRxChar) receiver #1 packet: 2030CF58A7
19-4-2012 17:49:29 - RFXCOM - (RecRxChar) receiver #1 packet: 2030CF7887
19-4-2012 17:49:29 - RFXCOM - (RecRxChar) receiver #1 packet: 2030CF58A7
If i put it in debug mode. But then i go to homeseer to rfxcom plugin, try and click on add it says "No devices found to add!"
Also checked in the virtual (you never know) but nothing.
I would think it would show up their no? This used to work and i didn't change a setting i just moved XP to Win7..
Also see that my other kaku (light sensor) doens't respond, so it looks like a kaku thing, rfxmeter and oregon sensor do come in normally.
I've set in the interfaces tab all the items to : Y Y Y Y Y Y Y , should be ok i suppose. I even removed them all and added them all to make sure they are set, didn't help.
So tell me which silly thing did i forget :)
b_weijenberg
Re: Kaku not showing up in homeseer
Post by b_weijenberg »
Configure house code P on the RFXCOM - X10 page to Status Only.
Enable X10 recive in the receiver configuration.
Create device P8 on the Homeseer status page and it displays the status of the push button
Snelvuur
Post by Snelvuur »
It comes in as P16, i assume the ligth sensor is different then the doorbel thinigy. Since i had that one in the past via the normal routine. "Kaku AC Input Device AC[6278889]a" anyway i know where to look now, just been a while since i used that one ;) thanks. And indeed silly mistake of me :)
