No. I don't read anything unusual. Still no bells.
Now I understand that your problem is probably not that the music player
stops playing, but that it will not
resume after the phone call has ended; right?
There are a lot of things we can do, but with "we" i actually mean "you". First some easy tasks:
- In this situation, where a problem can have multiple causes, i would like the scripts to be reviewed/modified so they don't trigger any more syntax errors or other issues. I need to know what exactly goes wrong. Second request.
- Send me your FBF.LOG. This log should contain at least 1 occurrence of the problems you have. I think you still have my mail address. I will have a look inside to see what's going on. Please do not edit or strip the contents of this file; i also need to see what happens when HS is started, for example.
- Temporarily disable all the events regarding the Fritz!Box. Try to reproduce the problems. Please report back the results.
If all this doesn't give any new information and the problem still exists, you'll have to do the following:
- Go back to version 0.6.4.1 (
http://www.hekkers.net/files/FBF_0641.rar)
- Check if version 0.6.4.1 can detect your Fritz!Box model.
- Report the Model/FW detected as shown on the Interface Settings page of the Plugin.
- Try to reproduce the problem you have with version 0.6.5.0, while using 0.6.4.1.
- Report your findings.
All this is necessary to eliminate possible causes.
