Page 1 of 3
Version 1.0.1.1
Posted: Wed Nov 14, 2012 8:42 pm
This release fixes some bugs:
- meppelink.net/cdfoon
did have a different response;
- HTML tags in the search results are removed.
http://www.hekkers.net/files/fbf_1011.rar
Re: Version 1.0.1.1
Posted: Wed Nov 14, 2012 9:26 pm
by stefxx
Thanks again. I'll try to install tonight and test again.
Keep up the good work!
Re: Version 1.0.1.1
Posted: Thu Nov 15, 2012 6:21 pm
by stefxx
Ok, after a day of testing I can confirm that the problem (with incorrect response) is solved.
Thanks again!
Re: Version 1.0.1.1
Posted: Fri Nov 16, 2012 6:14 pm
by RdP
Thanks Robert,
I still have one minor request. Is it possible to have a function which deletes a voicemail without playing it? Or is there any other way to do this.
It's hard to decide if you want to delete a voicemail before I have heard it. Maybe I like to keep for a while and decide later on to delete it.
I like to do this from my HSTouch screen, that's why I ask for a function.... I will post a HSTouch screenshot of the voicemail screen as soon as I finished it...
Best regards,
Re: Version 1.0.1.1
Posted: Fri Nov 16, 2012 6:36 pm
As in hs.Plugin("Fritz! Box").DeleteVoiceMail(0) ? And (1,2, etc)
Yes, that's possible, some time this weekend.
Re: Version 1.0.1.1
Posted: Fri Nov 16, 2012 10:32 pm
by RdP
Digit wrote:As in hs.Plugin("Fritz! Box").DeleteVoiceMail(0) ? And (1,2, etc).
Cool !!!
Yes that's what I mean....
/Rien
Re: Version 1.0.1.1
Posted: Fri Nov 16, 2012 11:05 pm
by stefxx
I am still having problems with the PlayVoiceMail function using HStouch. If I create an action with "HomeSeer: Run a HomeSeer script with values from elements(s)" and the script "&hs.speak("Hello world")" it works fine and audio is coming from the HStouch client. However, if I replace the script with "&hs.Plugin("Fritz! Box").PlayVoiceMail(0, False)" it only plays on my Homeseer server (with the speaker client active).
Putting the script in an event and triggering the event also doesn't work. Help?
Re: Version 1.0.1.1
Posted: Fri Nov 16, 2012 11:26 pm
Have you ever been able to play wav files on your HSTouch client?
Re: Version 1.0.1.1
Posted: Fri Nov 16, 2012 11:30 pm
BTW Version 1.0.2.0 is
here
Re: Version 1.0.1.1
Posted: Fri Nov 16, 2012 11:41 pm
by stefxx
Digit wrote:Have you ever been able to play wav files on your HSTouch client?
Yes. "Misc: Play a WAV sound file" works fine.
Re: Version 1.0.1.1
Posted: Fri Nov 16, 2012 11:42 pm
Don't understand. Tell me more. Mail me some stuff if you have to.
Re: Version 1.0.1.1
Posted: Fri Nov 16, 2012 11:48 pm
by stefxx
Digit wrote:Don't understand. Tell me more. Mail me some stuff if you have to.
What's more to tell? HStouch client seems to work fine (play wav and hs.speak both work) but the playvoicemail function does not, only on the speaker client. Tested on a Windows and Android HStouch client.
I could try installing a speaker client on the windows client. Not sure what I would learn from that.
What HStouch device(s) do you use? What platform? With or without a speaker client?
Re: Version 1.0.1.1
Posted: Sat Nov 17, 2012 12:24 am
What is that, a tooltip for a textbox or something, where you can type a filename? I'm not sure.
I'm blind in a way, I don't know what you're doing or trying to do.
In this case you (and all the others, actually) are the expert, I use neither HS nor HSTouch.
I am expecting help from your fellow users soon, cause not all seem to have this problem ????
Re: Version 1.0.1.1
Posted: Sat Nov 17, 2012 9:45 am
by stefxx
Thanks. I am not convinced it is an issue in your plugin, perhaps it is just something in my setup.
"Misc: Play a WAV sound file" is just one of the possible actions in Homeseer. You specify a wav file and that's it. I forgot you didn't use Homeseer
I think Rien has a working setup, I like to know how his setup looks like, and if he is using the homeseer speaker or only hstouch.
Re: Version 1.0.1.1
Posted: Sat Nov 17, 2012 10:29 am
by RdP
sddroog wrote:Thanks. I am not convinced it is an issue in your plugin, perhaps it is just something in my setup.
I have some things to do first and get back to you later today.....
Oh and the download link to version 1.0.2.0 doesn't work for me...
/Rien
