SNMP trap bug fixed
Forum over de Homeseer IPPower plugin van Rene Klootwijk (DUTCH forum)
Moderator: Rene
SNMP trap bug fixed
Postby Rene » Mon Nov 19, 2012 11:20 pm
On request of Olof I had a look at the long lasting SNMP trap bug causing Homeseer to crash and finally fixed it.
Re: SNMP trap bug fixed
Postby olof » Tue Nov 20, 2012 3:26 pm
I can confirm the new IPPlugin works great!
Thanks Rene!
The new IPPlugin with SNMP trap works like a charm with Homeseer Pro edition & IPPower 9212.
One tip: do not change the default names of the IPPower ports (IN 1 through IN8). I did and it created additional issues.
My application (for those interested):
-I hooked up my garden gate + 2 of its gate PIR's to the IPPower 9212.
- Using the new plugin w/SNMP Homeseer now knows within 1 second if anybody 'broke' the 2 PIR beams.
- Without the SNMP trap, it was a hit/miss in detection as the PIR status referts back to default within 1-2 seconds after somebody 'broke' the beam. To quick for the combo IPPower + Homeseer to detect without SNMP.
Next step: setting up events (somehow) which enables Homeseer to determine if somebody is leaving or entering the property. Depends on the sequence which PIR is broken first. I.e. if Pir 1 first, then Pir 2 = somebody is entering my garden. If Pir 2 first, then Pir 1 = somebody is leaving the garden.
Olof
olof
Postby r_255 » Tue Nov 20, 2012 9:49 pm
Thats great !
Thanks Rene, this opens up doors ;o)
have status on the sensors like the reed contacts i recovered from this old coffeemachine to check if the door is really closed and the mail box status.
r_255
Return to Homeseer IPPower Plugin Forum
