Android tablet blijft niet geconnect
Posted: Fri Dec 13, 2013 5:08 pm
by strongetje
hallo,
heb vandaag HS3 op mijn shutle pc geïnstalleerd.
HS3 v3.0.0.52 (met licentie)
HSTouch Server v3.0.0.11 (met licentie die ik bij HStouch server HS2 gekregen heb)
probleem is dat de android tablet steeds disconect en weer conect.
Dec-13 3:56:28 PM         HSTouch Server    GetAllThermostats:NONE
 Dec-13 3:56:25 PM         HSTouch Server    Client Android (10.0.0.23/35167) named Android has CONNECTED.
 Dec-13 3:56:25 PM         HSTouch Server    Opening connection from:10.0.0.23/35167
 Dec-13 3:55:52 PM         HSTouch Server    Client Android named Android has DISCONNECTED.
 Dec-13 3:55:52 PM         HSTouch Server    Client Android:Android (10.0.0.23/58848) has raised LineDisconnected.
 Dec-13 3:55:52 PM         HSTouch Server Warning    Client dropped connection 10.0.0.23/58848
 Dec-13 3:55:25 PM         HSTouch Server    GetAllThermostats:NONE
 Dec-13 3:55:21 PM         HSTouch Server    Client Android (10.0.0.23/58848) named Android has CONNECTED.
 Dec-13 3:55:21 PM         HSTouch Server    Opening connection from:10.0.0.23/58848
 Dec-13 3:54:39 PM         HSTouch Server    Client Android named Android has DISCONNECTED.
 Dec-13 3:54:39 PM         HSTouch Server    Client Android:Android (10.0.0.23/48746) has raised LineDisconnected.
 Dec-13 3:54:39 PM         HSTouch Server Warning    Client dropped connection 10.0.0.23/48746
 Dec-13 3:52:20 PM         HSTouch Server    GetAllThermostats:NONE
 Dec-13 3:52:17 PM         HSTouch Server    Client Android (10.0.0.23/48746) named Android has CONNECTED.
 Dec-13 3:52:17 PM         HSTouch Server    Opening connection from:10.0.0.23/48746
 Dec-13 3:51:22 PM         HSTouch Server    Client Android named Android has DISCONNECTED.
 Dec-13 3:51:22 PM         HSTouch Server    Client Android:Android (10.0.0.23/39306) has raised LineDisconnected.
 Dec-13 3:51:22 PM         HSTouch Server Warning    Client dropped connection 10.0.0.23/39306
 Dec-13 3:50:16 PM         HSTouch Server    GetAllThermostats:NONE
 Dec-13 3:50:13 PM         HSTouch Server    Client Android (10.0.0.23/39306) named Android has CONNECTED.
 Dec-13 3:50:13 PM         HSTouch Server    Opening connection from:10.0.0.23/39306
 Dec-13 3:49:52 PM         HSTouch Server    Client Android named Android has DISCONNECTED.
 Dec-13 3:49:52 PM         HSTouch Server    Client Android:Android (10.0.0.23/34435) has raised LineDisconnected.
 Dec-13 3:49:52 PM         HSTouch Server Warning    Client dropped connection 10.0.0.23/34435
 Dec-13 3:46:11 PM         HSTouch Server    GetAllThermostats:NONE
 Dec-13 3:46:07 PM         HSTouch Server    Client Android (10.0.0.23/34435) named Android has CONNECTED.
 Dec-13 3:46:07 PM         HSTouch Server    Opening connection from:10.0.0.23/34435
 Dec-13 3:46:07 PM         HSTouch Server    Client Android named Android has DISCONNECTED.
 Dec-13 3:46:07 PM         HSTouch Server    Client Android:Android (10.0.0.23/35042) has raised LineDisconnected.
 Dec-13 3:46:07 PM         HSTouch Server Warning    Client dropped connection 10.0.0.23/35042
 Dec-13 3:44:06 PM         HSTouch Server    GetAllThermostats:NONE
 Dec-13 3:44:03 PM         HSTouch Server    Client Android (10.0.0.23/35042) named Android has CONNECTED.
 Dec-13 3:44:03 PM         HSTouch Server    Opening connection from:10.0.0.23/35042
 Dec-13 3:43:52 PM         HSTouch Server    Client Android named Android has DISCONNECTED.
 Dec-13 3:43:52 PM         HSTouch Server    Client Android:Android (10.0.0.23/54563) has raised LineDisconnected.
 Dec-13 3:43:52 PM         HSTouch Server Warning    Client dropped connection 10.0.0.23/54563
 Dec-13 3:42:02 PM         HSTouch Server    GetAllThermostats:NONE
 Dec-13 3:41:59 PM         HSTouch Server    Client Android (10.0.0.23/54563) named Android has CONNECTED.
 Dec-13 3:41:58 PM         HSTouch Server    Opening connection from:10.0.0.23/54563
 Dec-13 3:41:37 PM         HSTouch Server    Client Android named Android has DISCONNECTED.
 Dec-13 3:41:37 PM         HSTouch Server    Client Android:Android (10.0.0.23/53051) has raised LineDisconnected.
 Dec-13 3:41:37 PM         HSTouch Server Warning    Client dropped connection 10.0.0.23/53051
"stay conected" is aangevinkt op de tablet.
als ik de op mijn laptop geïnstalleerde HS3(trail) start, en ik conect de android tablet met mijn laptop blijft deze gewoon geconect.
heb Hstouch opnieuw geïnstalleerd, maar dit lost het probleem niet op.
wie heeft er een mogelijke oplossing ?.
P.S. HS2 staat ook nog op de shuttle PC, maar is uiteraard gestopt.
bvd voor de info
mvg,
Mark
Re: Android tablet blijft niet geconect
Posted: Fri Dec 13, 2013 8:20 pm
by redleg
Beste Mark,
Er zijn 2 dingen die fout gaan.
1. Wanneer je scherm uit gaat, wordt je wifi ook uitgeschakeld. Je kunt bij de geavanceerde wifi opties in android kan je de optie aangeven dat hij altijd aan blijft.
2. Wanneer het scherm uitgaat blijft je wifi nu na de aanpassing van stap 1 aan. Echter komt deze wel in een soort van slaapstand (je krijgt een hoge ping op dat moment) Met de app Wifi High Preformance Widget kan je zorgen wanneer het scherm uitgaat het wifi signaal optimaal blijft werken.
Het scherm gaat bij mij na 2 min uit. Met met een trigger (beweging) vanauit homeseer roep ik een app aan op de tablet genaamd WakeUp2. Deze zorgt dat het scherm weer oplicht.
Succes.
Posted: Fri Dec 13, 2013 8:42 pm
by strongetje
hallo redleg,
hartelijk dank voor de reactie.
de tablet gaat nooit in slaapstand, deze hangt constant aan de voeding.
in HS2 nooit problemen mee gehad.
met de trail versie van HS3 op de laptop ook geen problemen.
alleen problemen als ik HS3 vanaf mijn shuttlePC draai.
dus probleem lijkt me niet bij de Android Tablet te liggen !.
mvg,
Mark
Posted: Fri Dec 13, 2013 8:53 pm
by redleg
mmmm, ik had hem even beter moeten lezen ;) Ik had mijn oordeel te snel klaar na ervaring van de hobby hier thuis...
Ik zat nog even te denken. Misschien is het de firewall? Weet niet welke versie Windows je draait.
Posted: Fri Dec 13, 2013 9:18 pm
by strongetje
hallo,
draai windows7 professional.
firewall had ik al uitgezet.
heb op de Tablet "Wifi High Preformance" geïnstalleerd, maar probleem blijft.
heb zojuist HS2 compleet verwijderd, maar helpt ook niet.
denk dat ik morgen de shuttlePC maar eens opnieuw ga installeren.
mvg,
Mark
Re: Android tablet blijft niet geconnect
Posted: Sat Dec 28, 2013 6:41 pm
by Bastiaan
IK heb de zelfde problemen: alles werkte perfect in HS2 maar Android en HS3 ljkt mist te gaan. Mijn Ipads hebben geen enkel probleem met verbinden.
Posted: Sun Dec 29, 2013 10:29 am
by strongetje
hallo Bastiaan,
ik heb mijn shuttle PC opnieuw geïnstalleerd, en heb hierna geen problemen meer gehad.
ik moest in de bios zijn voor de boot aan te passen, en kwam er toen achter dat de tijd en datum niet meer goed stonden.
weet niet of het hier aan gelegen heeft, maar kijk even voor de zekerheid of bij jou de datum en tijd nog goed staan.
mvg,
Mark
Posted: Sun Dec 29, 2013 11:08 am
by Bastiaan
Hi Mark, alle device in huis gebruiken en timeserver om de tijd te zetten en zijn allen in sync. Wel is het zo dat Android device dat vaak niet kunnen en dus handmatig ingesteld moeten worden. Helaas is dit het issue niet.
De dubbel check is natuurlijk dat op dezelfde server HS2 draait en daar werkt HStouch prima mee. Het lijkt dus alsof de HStouch server / Android plugin niet OK is.
