Influx Grafana Script
Postby raymonvdm » Wed Mar 20, 2019 3:17 pm
I have found a script which logs all device values to an InfluxDB so i can use them with Grafana. The script is running fine, but Windows 10 seems to be limited in its capabilities to log the data to an Influx database running on another machine.
The solution would be to run the InfluxDB on the same machine as HS3 but i already have an Influx Ubuntu VM running which i would like to use
https://forums.homeseer.com/forum/homes ... fana/page4
Can anybody help me to get it going correctly?
I already modified the script by adding the following rule
ServicePointManager.DefaultConnectionLimit = 200
raymonvdm
Return to Homeseer Scripts Forum
