Homeseer Script to monitor & Control ELV MAX! Thermostats
labtec
Re: Homeseer Script to monitor & Control ELV MAX! Thermostats
Post by labtec »
labtec wrote:Thanks for this script, nice to control the ELV MAX via HS3, I have the following errors in my log;
feb-10 18:24:24 Database There were errors generated during the save of the database item. Please consult this log for more details and report any data loss to HomeSeer Technologies.
feb-10 18:24:24 Database ERROR, device Max! Heating Timezone failed to be updated or added to the database.
feb-10 18:24:24 Error SQL Exception adding device record to the database: SQL logic error or missing databaseunrecognized token: "'CET", Code=1, Link=
Thanks
I got the above errors only the first time when running the script, I just run it another time and the where no database errors :?:
wmccann
Post by wmccann »
Check if you have a device (Housecode)2 - this is the timezone device - the status on mine is "GMT/IST". Not sure what it's function is - never really bothered with it - it was in the original script by blb.
I did see some database errors during my testing - but I think mine were due to RFComm unit that I use.
Check what version your max! is on - mine is on v 1.4
Hope this helps,
W.
JoopK
Post by JoopK »
There seems to be an issue with my thermostate:
14-2-2014 21:16:05  Event  Event Trigger "Max status"
14-2-2014 21:16:05  Event  Running script in background: BLB_Max_monitor 02.vb
14-2-2014 21:16:05  Max_debug1  SWversion: 0.2p
14-2-2014 21:16:15  Max_debug2  Full Reply: H:JEQ0544997,03f211,0113,00000000,06947759,00,32,0e020e,1510,03,0000M:00,01,VgIDAQlXb29ua2FtZXII76sCB0thbnRvb3II7wMDCEJhZGthbWVyCO90BAEI76tLRVEwNjUwMzI5BktldWtlbgEBCO8DS0VRMDY1MDUxMAdLYW50b29yAgEI73RLRVEwNjUwNDA1CEJhZGthbWVyAwMJT+BLRVEwNTA1MjYwEVdhbGwgVGhlcm1vc3RhdCAxAgE=C:03f211,7QPyEQATAf9KRVEwNTQ0OTk3AAsABEAAAAAAAAAAAP///////////////////////////wsABEAAAAAAAAAAQf///////////////////////////2h0dHA6Ly9tYXguZXEtMy5kZTo4MC9jdWJlADAvbG9va3VwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAENFVAAACgADAAAOEENFU1QAAwACAAAcIA==C:08ef74,0gjvdAEDGP9LRVEwNjUwNDA1KyE9CQcYAzAM/wAoVHh+KSApICkgKSApIEUgRSBFIEUgRSBFIChUeH4pICkgKSApICkgRSBFIEUgRSBFIEUgKFR4fikgKSApICkgKSBFIEUgRSBFIEUgRSAoVHh+KSApICkgKSApIEUgRSBFIEUgRSBFIChUeH4pICkgKSApICkgRSBFIEUgRSBFIEUgKFR4fikgKSApICkgKSBFIEUgRSBFIEUgRSAoVHh+KSApICkgKSApIEUgRSBFIEUgRSBFIA==C:094fe0,zglP4AMCEP9LRVEwNTA1MjYwKCE9CURIVRRVIFUgVSBVIFUgRSBFIEUgRSBFIEUgREhVFFUgVSBVIFUgVSBFIEUgRSBFIEUgRSApICkgKSApICkgKSApIEUgRSBFIEUgRSBFICkgKSApICkgKSApICkgRSBFIEUgRSBFIEUgREhVFFUgVSBVIFUgVSBFIEUgRSBFIEUgRSBESFUUVSBVIFUgVSBVIEUgRSBFIEUgRSBFIERIVRRVIFUgVSBVIFUgRSBFIEUgRSBFIEUgBxgwC:08ef03,0gjvAwECGP9LRVEwNjUwNTEwKCE9CQcYAzAM/wApICkgKSApICkgKSApIEUgRSBFIEUgRSBFICkgKSApICkgKSApICkgRSBFIEUgRSBFIEUgKSApICkgKSApICkgKSBFIEUgRSBFIEUgRSApICkgKSApICkgKSApIEUgRSBFIEUgRSBFICkgKSApICkgKSApICkgRSBFIEUgRSBFIEUgKSApICkgKSApICkgKSBFIEUgRSBFIEUgRSApICkgKSApICkgKSApIEUgRSBFIEUgRSBFIA==C:08efab,0gjvqwEBGP9LRVEwNjUwMzI5KyE9CQcYAzAM/wB5IHkgeSB5IHkgeSB5IEUgRSBFIEUgRSBFIHkgeSB5IHkgeSB5IHkgRSBFIEUgRSBFIEUgeSB5IHkgeSB5IHkgeSBFIEUgRSBFIEUgRSB5IHkgeSB5IHkgeSB5IEUgRSBFIEUgRSBFIHkgeSB5IHkgeSB5IHkgRSBFIEUgRSBFIEUgeSB5IHkgeSB5IHkgeSBFIEUgRSBFIEUgRSB5IHkgeSB5IHkgeSB5IEUgRSBFIEUgRSBFIA==L:CwjvdAkSGAAYAAAADAlP4PESGAEYAAAA0AsI7wMJEhgAGAAAAAsI76sJEhhEPAD/AA==
14-2-2014 21:16:15  Max_debug2  H: JEQ0544997,03f211,0113,00000000,06947759,00,32,0e020e,1510,03,0000
14-2-2014 21:16:15  Info  H: Cubedate: 14-2-2014 21:16:00 systemtime: 14-2-2014 21:16:15 Datediff: 0
14-2-2014 21:16:15  Max_debug1  H: Cube Serial number: JEQ0544997 Cube Address: 258577 Cube Firmware: 275 Cube Date: 14-2-2014 21:16:00
14-2-2014 21:16:15  Max_debug2  M: 00,01,VgIDAQlXb29ua2FtZXII76sCB0thbnRvb3II7wMDCEJhZGthbWVyCO90BAEI76tLRVEwNjUwMzI5BktldWtlbgEBCO8DS0VRMDY1MDUxMAdLYW50b29yAgEI73RLRVEwNjUwNDA1CEJhZGthbWVyAwMJT+BLRVEwNTA1MjYwEVdhbGwgVGhlcm1vc3RhdCAxAgE=
14-2-2014 21:16:15  Max_debug2  M: 00 01 5602030109576F6F6E6B616D657208EFAB02074B616E746F6F7208EF0303084261646B616D657208EF74040108EFAB4B455130363530333239064B65756B656E010108EF034B455130363530353130074B616E746F6F72020108EF744B455130363530343035084261646B616D65720303094FE04B4551303530353236301157616C6C20546865726D6F7374617420310201
14-2-2014 21:16:15  Max_debug1  M: #rooms: 3 RoomNumber: 1 RoomName: Woonkamer 1stAddressInRoom: 585643
14-2-2014 21:16:15  Max_debug1  M: #rooms: 3 RoomNumber: 2 RoomName: Kantoor 1stAddressInRoom: 585475
14-2-2014 21:16:15  Max_debug1  M: #rooms: 3 RoomNumber: 3 RoomName: Badkamer 1stAddressInRoom: 585588
14-2-2014 21:16:15  Max_debug1  M: #Devices: 4 DeviceType: 01 DeviceAddress: 585643 SN: KEQ0650329 DeviceName: Keuken DeviceRoom: 1
14-2-2014 21:16:15  Max_debug1  M: #Devices: 4 DeviceType: 01 DeviceAddress: 585475 SN: KEQ0650510 DeviceName: Kantoor DeviceRoom: 2
14-2-2014 21:16:15  Max_debug1  M: #Devices: 4 DeviceType: 01 DeviceAddress: 585588 SN: KEQ0650405 DeviceName: Badkamer DeviceRoom: 3
14-2-2014 21:16:15  Max_debug1  M: #Devices: 4 DeviceType: 03 DeviceAddress: 610272 SN: KEQ0505260 DeviceName: Wall Thermostat 1 DeviceRoom: 2
14-2-2014 21:16:15  Max_debug1  C1: address: 258577 type: 00 SerialNR: JEQ0544997
14-2-2014 21:16:15  Max_debug2  C: C response: ED03F211001301FF4A455130353434393937000B0004400000000000000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0B0004400000000000000041FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF687474703A2F2F6D61782E65712D332E64653A38302F6375626500302F6C6F6F6B75700000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000043455400000A000300000E10434553540003000200001C20
14-2-2014 21:16:15  Max_debug2  C: C Cube response: CET CEST
14-2-2014 21:16:15  Max_debug2  C1: response: ED03F211001301FF4A455130353434393937000B0004400000000000000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0B0004400000000000000041FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF687474703A2F2F6D61782E65712D332E64653A38302F6375626500302F6C6F6F6B75700000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000043455400000A000300000E10434553540003000200001C20
14-2-2014 21:16:15  Max_debug1  C2: address: 585588 type: 01 SerialNR: KEQ0650405
14-2-2014 21:16:15  Max_debug1  C2: za 7 (1) 10/07:00 (2) 30/10:30 (3) 10/00:00
14-2-2014 21:16:15  Max_debug1  C2: zo 7 (1) 10/07:00 (2) 30/10:30 (3) 10/00:00
14-2-2014 21:16:15  Max_debug1  C2: ma 7 (1) 10/07:00 (2) 30/10:30 (3) 10/00:00
14-2-2014 21:16:15  Max_debug1  C2: di 7 (1) 10/07:00 (2) 30/10:30 (3) 10/00:00
14-2-2014 21:16:15  Max_debug1  C2: wo 7 (1) 10/07:00 (2) 30/10:30 (3) 10/00:00
14-2-2014 21:16:15  Max_debug1  C2: do 7 (1) 10/07:00 (2) 30/10:30 (3) 10/00:00
14-2-2014 21:16:15  Max_debug1  C2: vr 7 (1) 10/07:00 (2) 30/10:30 (3) 10/00:00
14-2-2014 21:16:15  Max_debug1  C2: ComT: 21,5 EcoT: 16,5 MaxT: 30,5 MinT: 4,5 OffT: 0 WinT: 12 WinDur: 03 Boostdur: 1 BoostVal: 80% datetime_decal: za 12:00u Valve_Max: 100 Valve_off: 0 Firmware: 24
14-2-2014 21:16:15  Max_debug2  C2: response: D208EF74010318FF4B4551303635303430352B213D09071803300CFF002854787E292029202920292029204520452045204520452045202854787E292029202920292029204520452045204520452045202854787E292029202920292029204520452045204520452045202854787E292029202920292029204520452045204520452045202854787E292029202920292029204520452045204520452045202854787E292029202920292029204520452045204520452045202854787E29202920292029202920452045204520452045204520
14-2-2014 21:16:15  Max_debug1  C3: address: 610272 type: 03 SerialNR: KEQ0505260
14-2-2014 21:16:15  Error  Max Monitor; C3: unknown device: 03
14-2-2014 21:16:15  Max_debug2  C3: response: CE094FE0030210FF4B45513035303532363028213D094448551455205520552055205520452045204520452045204520444855145520552055205520552045204520452045204520452029202920292029202920292029204520452045204520452045202920292029202920292029202920452045204520452045204520444855145520552055205520552045204520452045204520452044485514552055205520552055204520452045204520452045204448551455205520552055205520452045204520452045204520071830
14-2-2014 21:16:15  Max_debug1  C4: address: 585475 type: 01 SerialNR: KEQ0650510
14-2-2014 21:16:15  Max_debug1  C4: za 7 (1) 10/00:00
14-2-2014 21:16:15  Max_debug1  C4: zo 7 (1) 10/00:00
14-2-2014 21:16:15  Max_debug1  C4: ma 7 (1) 10/00:00
14-2-2014 21:16:15  Max_debug1  C4: di 7 (1) 10/00:00
14-2-2014 21:16:15  Max_debug1  C4: wo 7 (1) 10/00:00
14-2-2014 21:16:15  Max_debug1  C4: do 7 (1) 10/00:00
14-2-2014 21:16:15  Max_debug1  C4: vr 7 (1) 10/00:00
14-2-2014 21:16:15  Max_debug1  C4: ComT: 20 EcoT: 16,5 MaxT: 30,5 MinT: 4,5 OffT: 0 WinT: 12 WinDur: 03 Boostdur: 1 BoostVal: 80% datetime_decal: za 12:00u Valve_Max: 100 Valve_off: 0 Firmware: 24
14-2-2014 21:16:15  Max_debug2  C4: response: D208EF03010218FF4B45513036353035313028213D09071803300CFF002920292029202920292029202920452045204520452045204520292029202920292029202920292045204520452045204520452029202920292029202920292029204520452045204520452045202920292029202920292029202920452045204520452045204520292029202920292029202920292045204520452045204520452029202920292029202920292029204520452045204520452045202920292029202920292029202920452045204520452045204520
14-2-2014 21:16:15  Max_debug1  C5: address: 585643 type: 01 SerialNR: KEQ0650329
14-2-2014 21:16:15  Max_debug1  C5: za 7 (1) 30/00:00
14-2-2014 21:16:15  Max_debug1  C5: zo 7 (1) 30/00:00
14-2-2014 21:16:15  Max_debug1  C5: ma 7 (1) 30/00:00
14-2-2014 21:16:15  Max_debug1  C5: di 7 (1) 30/00:00
14-2-2014 21:16:15  Max_debug1  C5: wo 7 (1) 30/00:00
14-2-2014 21:16:15  Max_debug1  C5: do 7 (1) 30/00:00
14-2-2014 21:16:15  Max_debug1  C5: vr 7 (1) 30/00:00
14-2-2014 21:16:15  Max_debug1  C5: ComT: 21,5 EcoT: 16,5 MaxT: 30,5 MinT: 4,5 OffT: 0 WinT: 12 WinDur: 03 Boostdur: 1 BoostVal: 80% datetime_decal: za 12:00u Valve_Max: 100 Valve_off: 0 Firmware: 24
14-2-2014 21:16:15  Max_debug2  C5: response: D208EFAB010118FF4B4551303635303332392B213D09071803300CFF007920792079207920792079207920452045204520452045204520792079207920792079207920792045204520452045204520452079207920792079207920792079204520452045204520452045207920792079207920792079207920452045204520452045204520792079207920792079207920792045204520452045204520452079207920792079207920792079204520452045204520452045207920792079207920792079207920452045204520452045204520
14-2-2014 21:16:15  Max_debug2  L: lenght: 98 L: response: 0B08EF7409121800180000000C094FE0F112180118000000D00B08EF0309121800180000000B08EFAB091218443C00FF00
14-2-2014 21:16:15  Max_debug2  L: Device 1: 0B08EF740912180018000000
14-2-2014 21:16:15  Max_debug1  L: 0B08EF740912180018000000 IST: 0 Mode: 00 HEX: 0000
14-2-2014 21:16:15  Max_debug1  L: address: 585588 tvalid: 1 Terror: 0 Tanswer: 0 mode: Auto Valve: 0% Temp: 12 date: --
14-2-2014 21:16:15  Max_debug1  L: no Thermostat, Length L: command= 12!
14-2-2014 21:16:15  Max_debug2  L: Device 3: 0B08EF030912180018000000
14-2-2014 21:16:15  Max_debug1  L: 0B08EF030912180018000000 IST: 0 Mode: 00 HEX: 0000
14-2-2014 21:16:15  Max_debug1  L: address: 585475 tvalid: 1 Terror: 0 Tanswer: 0 mode: Auto Valve: 0% Temp: 12 date: --
14-2-2014 21:16:15  Max_debug2  L: Device 4: 0B08EFAB091218443C00FF00
14-2-2014 21:16:15  Max_debug1  L: 0B08EFAB091218443C00FF00 IST: 25,5 Mode: 00 HEX: 00FF
14-2-2014 21:16:15  Max_debug1  L: address: 585643 tvalid: 1 Terror: 0 Tanswer: 0 mode: Auto Valve: 68% Temp: 30 date: --
14-2-2014 21:16:15  debugn4 s:  558564321,5
14-2-2014 21:16:15  debugn4 s:  458547520
14-2-2014 21:16:15  debugn4 s:  258558821,5
14-2-2014 21:16:15  Max_debug0  Create Radiator Thermostat Device: M25
14-2-2014 21:16:15  Error  Max Monitor: De index ligt buiten de matrixgrenzen. You probably need to increase the WaitSec value in the .ini file.
There room "kantoor" is not created and the creation of the wall thermostate results in an error. I am running the original script.
JoopK
Post by JoopK »
I checked the script and indeed type 03 is not supported. I assume this is the wall thermostate?
Sent from my Nexus 7 using Tapatalk
pbrand
Post by pbrand »
JoopK wrote:I checked the script and indeed type 03 is not supported. I assume this is the wall thermostate?
A correct assumption indeed.
Cube = 0,
RadiatorThermostat = 1,
RadiatorThermostatPlus = 2,
WallThermostat = 3,
ShutterContact = 4,
EcoButton = 5
JoopK
Post by JoopK »
I updated the script to skip the wall thermastate. I did it based on the address (in my case 621272). But I think there are better ways to do this? I tried with the device type C_type but the table does not match the numer of the device in this section.
I remove the unkown device messageby adding a Case "03". (The wall themostate can work directly, no need for it in homeseer).
I added the command temp to set a radiator thermoste to a value from another device (in my case T2 in farenheid*100).
I quoted out some double debug writelogs.
I removed the coding to restore the temperature to the homeseer setting (because I can override with the wall thermostate, and also directly on the radiator thermostate?)
Arrays were defined with Tcnt = 20 and in the coding there was a check on 100.... (only causing trouble with devicetype other than 00 an 01...)
I maked the changes with JK.
' Script : max_monitor script
' Purpose: communication with Max! Gateway
' Author : BLB
' Version: 02p 20130211 Some bugfixes to temp setting via listboxes by storing / comparing required temp in INI file
' Version: 02o 20130120	changed device type with MAX part (Cube or RT), Serial number/address/Firmware version/[device number];
'						removed seperate device with Serial number/address/Firmware version/[device number]
'						changed MAX!RT device value "Mode/Setpnt/Valve%/EndDateTime" to Setpoint value
'						added MAX!RT device "Current Temperature" (Corrected with Offset). The current temperature is not always available, the device value/string stay untouched in that case
'						added option to hide status IF status = OK and hide Temperatures via .ini file
'						added WaitSec option in .ini file to set the waittime (for response from cube) in the .ini file. Too short time can lead to out of array error as found by Fischi
'						modified Firmware version output to Decimal (and not HEX)
'						added listboxes for temperature control for each Radiator Termostat, setpoint can be set via this listbox
' Version: 02n 20121219 added latest update time Thermostat Status after change device string
' Version: 02m 20121025 added firmware version Thermostats
' Version: 02l 20121004 added comment for solution for out of array error found by Fischi
' Version: 02k 20120504 improved C: response decoding, now response from other devices (wall switch, wall Thermostat) will be skipped properly
' Version: 02j 20120109 adapted debug setup. debug levels 0 (no), 1 (all full decoded info), 2 (1 + all base64 decoded info)
' Version: 02i 20120108 improved L: response decoding, now response from other devices (wall switch, wall Thermostat) with other response lenght will be skipped properly
' Version: 02h 20120108 added DevLocationswitched parameter in ini file to interchange location1 and location2
' Version: 02g 20111107 added Valve setting in device value (XXxYYY, XXx=temp zetting, YYY is valve opening in %) and sending Boost command
' Version: 02f 20111103 added additional options for end time in s: command
' Version: 02e 20111102 corrected room & device allocation, added timezone info for Cube
' Version: 02d 20111026 added s: command & Cube time (check)
' Version: 02c 20111002 added l: command and started with implementation s: command
' Version: 02b 20111002 added Tvalve() (current valve opening)
' Version: 02a 20110930 initial release
' usage:
' run script without parameters: update all devices, if devices don't exist in HS already they will be created
' run script with parameters:
'   ("Main","s:|<room>|<temperature>[|<mode>[|<enddate&time>]]")
'   room            roomnumber. if room = 0 then update for all rooms
'   temperature     can be the temperature (xx degrees or xx,5 degrees in range 4,5..30,5), auto (back to week schedule),
'                   com (comfort temp), eco (eco temp) and win (window open temp) are also allowed
'   mode            a (Auto) or "" (ommited): back to weekschedule on the first weekschedule change time
'                   b (Boost)               : only boost activation, independent from temp
'                   p (permanent)           : temperature will stay until next (manual) change
'                   t (Temporary)           : temperature will be set until the given date & time
'   enddate&time    YYYYMMDDHHMM            : the end date & time
'                   DDHHMM                  : days, hours and minutes later than current time
' import required modules
Imports System.Net
Imports System.Net.Sockets
Imports System.Text
Const INI_FILE As String = "hssi_BLB_Max_monitor.ini"        ' name ini file
Const swversion = "0.2p"                                     ' the version of this file
Sub Main(ByVal varParameters)
	'define variables
        Dim Tcnt As Integer = 20
	Dim Client			As New TcpClient()
	Dim strHC			As String  = hs.GetINISetting("Startup", "HouseCode", "", INI_FILE)                      ' house code
	Dim DevLocation		As String  = hs.GetINISetting("Startup", "DevLocation", "", INI_FILE)
	Dim RemoteIP		As String  = hs.GetINISetting("Startup", "TCPAddress", "", INI_FILE)
	Dim PortNumber		As Integer = Val(hs.GetINISetting("Startup", "TCPPort", "", INI_FILE))
	Dim WaitSec			As Integer = Val(hs.GetINISetting("Startup", "WaitSec", "3", INI_FILE))
	Dim DevLocsw		As Boolean = hs.GetINISetting("Startup", "DevLocationswitched", "", INI_FILE)
	Dim Debug			As Integer = Val(hs.GetINISetting("Startup", "Debug", "3", INI_FILE))
	Dim HideStatusOK	As Boolean = hs.GetINISetting("Startup", "HideStatusOK", "FALSE", INI_FILE)
	Dim HideTemps		As Boolean = hs.GetINISetting("Startup", "HideTemperatures", "FALSE", INI_FILE)
	Dim strDC			As String  = hs.GetINISetting("Cube", "FirstDeviceCode", "", INI_FILE)
	Dim strDV			As String  = strHC & strDC
	Dim Temp			As String
	Dim Message			As String
	Dim SetSetpoint		As Boolean = True
	Dim ResponseH, ResponseM, ResponseC(Tcnt),ResponseL  As String
	Dim ResponseH_SN, ResponseH_Ad,ResponseH_Fw, ResponseH_P4, ResponseH_P5, ResponseH_P6, ResponseH_P7, ResponseH_P8, ResponseH_P9 As String
	Dim ResponseH_Ye, ResponseH_Mo, ResponseH_Da, ResponseH_Ho, ResponseH_Mi, ResponseH_Date As String
	Dim Date_error_Mi
	Dim ResponseM_P1, ResponseM_P2, ResponseM_P3
	Dim PositionH, PositionM, PositionC(Tcnt), PositionL As String
	Dim Seperator(Tcnt) as Integer
	Dim Counter As Integer = 0
	Dim M_Rnumber(Tcnt), M_Rname(Tcnt), M_Raddress(Tcnt) , M_D_Type(Tcnt), M_Daddress(Tcnt), M_D_SN(Tcnt) As String
	Dim M_D_room(Tcnt) , M_DName(Tcnt), M_DRoom(Tcnt) As String
	Dim Name_Length, M_pointer, M_R_count, M_D_count, M_Rooms, M_Devices, Mi As Integer
	Dim Caddress(Tcnt), C_type(Tcnt), C_SN(Tcnt), C_Firmware(Tcnt), C_Week(Tcnt) As String
	Dim C_Cube_WT, C_Cube_ST As String
	Dim C_Cube_TV As Long
	Dim C_Com_Temp(Tcnt), C_Eco_Temp(Tcnt), C_Max_Temp(Tcnt), C_Min_Temp(Tcnt), C_Off_Temp(Tcnt), C_Win_Temp(Tcnt) As single
	Dim C_Win_Dura(Tcnt), C_Dur_Boos(Tcnt), C_Val_Boos(Tcnt), C_Dti_deca(Tcnt), C_max_Valv(Tcnt), C_off_Valv(Tcnt) As String
	Dim C_Wk(7) As String
	Dim Taddress(Tcnt), Tvalid(Tcnt), Terror(Tcnt), Tanswer(Tcnt), Tstatus(Tcnt), TstatusT(Tcnt) As String
	Dim Tbattery(Tcnt), Tlinkstatus(Tcnt), Tpanel(Tcnt), Tgateway(Tcnt), Tdts(Tcnt), Tmode1(Tcnt), Tmode2(Tcnt) As String
	Dim TTemp(Tcnt), Tvalve(Tcnt) As Single
	Dim Tdate(Tcnt), Ttime(Tcnt), TdateTime(Tcnt), Tist(Tcnt) As String
	Dim MaxCommand, s_roomc, s_mode, s_enddt  As String
	Dim s_room  As Integer
	Dim Tyy, Tmm, Tdd, Tda, Thh, IST As String
	dim dv2 as Object
	If debug > 0 Then hs.WriteLog("Max_debug1", "SWversion: " & swversion)
	If varParameters = "" Or varParameters = "l:" Then
		MaxCommand = varParameters
	ElseIf Left(varParameters,2) = "s:"
		' IF s:,   1st parameter = command (always "s:")
		'          2nd parameter = roomnumber. If 0 all rooms
		'          3rd parameter = temperature. auto, com (comfort temp), eco (eco temp), win (window open temp)
		'                                       and bst (boost command) are also allowed
		' optional 4rd parameter = mode. A (Auto), B (Boost), P (Permanent), T (Temporary). If T then 5th parameter
		'                          is also required
		' optional 5th parameter = end date & time. yymmddhhmm
		Maxcommand = hs.stringitem(varParameters, 1, "|")
		s_room     = hs.stringitem(varParameters, 2, "|")
		s_roomc    = hs.stringitem(varParameters, 3, "|")
		s_mode     = LCase(hs.stringitem(varParameters, 4, "|"))
		s_enddt    = hs.stringitem(varParameters, 5, "|")
		If debug > 1 Then hs.WriteLog("Max_debug2", "s: command: " & Maxcommand & " room: " & s_room & " roomcmd: " & s_roomc & " mode: " & s_mode)
	Else
		hs.WriteLog("Error", "Max Monitor; Unknown command: " & varParameters)
	End If
	'Device Names for Cube (n1) and Thermostats (n2)
	Dim n1(3), n2(5)
	n1(1)= "System date & Time"
	n1(2)= "Timezone"
	n2(1)= "Temperatures"
	n2(2)= "Status"
	n2(3)= "Program Today (Temp/Time)"
	n2(4)= "Mode/Setpnt/Valve%/EndDateTime"
	n2(5)= "Current Temperature"
	Try
		' Connect to the remote
		Client.Connect(IPAddress.Parse(RemoteIP), PortNumber)
		Dim NetStream As NetworkStream = Client.GetStream()
		' Receive reply. After initial Connect, the Cube gives always an initial response with all?? info
		hs.WaitSecs(WaitSec)
		Dim Reply As String = ReadString(Client)
		If debug > 1 Then hs.WriteLog("Max_debug2", "Full Reply: " & Reply)              ' full reply to logfile
		' Search seperators (:) in initial response string and put all fields in seperate variables Seperator()
		Seperator(Counter) = 1
		Do Until Seperator(Counter) = 0
			Seperator(Counter+1) = InStr(Seperator(Counter)+1,Reply,":")
			Counter += 1                                       ' counter hold number of fields in the reply
		Loop
		' Search the different responses from the initial response string and split them in all known parameters
		Dim i As Integer                                     ' i = counter to the number of fields in reply
		Dim dev As Integer = 1
		For i = 1 To counter-1
			If i = counter-1 Then Seperator(i+1) = Reply.length
			Select Case Mid(Reply,Seperator(i)-1,2)
				Case "H:"                                      ' The H response contains information about the Cube.
					ResponseH = Mid(Reply,Seperator(i)+1,Seperator(i+1)-Seperator(i)-2)
					If debug > 1 Then hs.WriteLog("Max_debug2", "H: " & ResponseH)
					ResponseH_SN = hs.StringItem(ResponseH,1,",")
					ResponseH_Ad = Hex2Dec(hs.StringItem(ResponseH,2,","))
					ResponseH_Fw = Hex2Dec(hs.StringItem(ResponseH,3,","))
					ResponseH_P4 = hs.StringItem(ResponseH,4,",")
					ResponseH_P5 = hs.StringItem(ResponseH,5,",")
					ResponseH_P6 = hs.StringItem(ResponseH,6,",")
					ResponseH_P7 = hs.StringItem(ResponseH,7,",")
					ResponseH_P8 = hs.StringItem(ResponseH,8,",")
					ResponseH_P9 = hs.StringItem(ResponseH,9,",")
					ResponseH_Ye = Hex2Dec(Mid(ResponseH_P8,1,2))+2000
					ResponseH_Mo = Hex2Dec(Mid(ResponseH_P8,3,2))
					ResponseH_Da = Hex2Dec(Mid(ResponseH_P8,5,2))
					ResponseH_Ho = Hex2Dec(Mid(ResponseH_P9,1,2))
					ResponseH_Mi = Hex2Dec(Mid(ResponseH_P9,3,2))
					ResponseH_Date = CDate(ResponseH_Ye & "-" & ResponseH_Mo &  "-" &ResponseH_Da & " " & ResponseH_Ho & ":" & ResponseH_Mi)
					Date_error_Mi = DateDiff("n",ResponseH_Date,now())
					hs.WriteLog("Info", "H: Cubedate: " & ResponseH_Date & " systemtime: " & now() & " Datediff: " & DateDiff("n",ResponseH_Date,now()))
					If debug > 0 Then hs.WriteLog("Max_debug1", "H: Cube Serial number: " & ResponseH_SN & " Cube Address: " & ResponseH_Ad & " Cube Firmware: " & ResponseH_Fw & " Cube Date: " & ResponseH_Date)
				Case "M:"                                      ' The M response contains Metadata; rooms, device names etc
					ResponseM = Mid(Reply,Seperator(i)+1,Seperator(i+1)-Seperator(i)-2)
					If debug > 1 Then hs.WriteLog("Max_debug2", "M: " & ResponseM)
					ResponseM_P1 = hs.StringItem(ResponseM,1,",")
					ResponseM_P2 = hs.StringItem(ResponseM,2,",")
					ResponseM_P3 = Base64ToHex(hs.StringItem(ResponseM,3,","))
					If debug > 1 Then hs.WriteLog("Max_debug2", "M: " & ResponseM_P1 & " " & ResponseM_P2 & " " & ResponseM_P3)
					M_pointer     = 5
					M_R_count     = 1
					M_Rooms       = Val("&H" & Mid(ResponseM_P3,M_pointer,2))
					M_pointer    += 2
					For Mi = 1 To M_Rooms
						M_Rnumber(Mi)  = Val("&H" & Mid(ResponseM_P3,M_pointer,2))
						M_pointer     += 2
						Name_Length    = Val("&H" & Mid(ResponseM_P3,M_pointer,2)) * 2
						M_pointer     += 2
						M_RName(Mi)    = Hex2asc(Mid(ResponseM_P3,M_pointer,Name_Length))
						M_pointer     += Name_Length
						M_Raddress(Mi) = Hex2Dec(Mid(ResponseM_P3,M_pointer,6))
						M_pointer     += 6
						If debug > 0 Then hs.WriteLog("Max_debug1", "M: #rooms: " & CStr(M_rooms) & " RoomNumber: " & CStr(M_Rnumber(Mi)) & " RoomName: " & _
										M_RName(Mi) & " 1stAddressInRoom: " & M_Raddress(Mi))
					Next
					M_R_count     = 1
					M_Devices     = Val("&H" & Mid(ResponseM_P3,M_pointer,2))
					M_pointer    += 2
					For Mi = 1 To M_Devices
						M_D_type(Mi)    = Mid(ResponseM_P3,M_pointer,2)
						M_pointer      += 2
						M_Daddress(Mi)  = Hex2Dec(Mid(ResponseM_P3,M_pointer,6))
						M_pointer      += 6
						M_D_SN(Mi)      = Hex2asc(Mid(ResponseM_P3,M_pointer,20))
						M_pointer      += 20
						M_pointer      += 2
						M_DName(Mi)     = Hex2asc(Mid(ResponseM_P3,M_pointer,Name_Length))
						M_DRoom(Mi)     = Val("&H" & Mid(ResponseM_P3,M_pointer,2))
						M_pointer      += 2
						If debug > 0 Then hs.WriteLog("Max_debug1", "M: #Devices: " & CStr(M_Devices) & " DeviceType: " & M_D_type(Mi) & _
										" DeviceAddress: " & M_Daddress(Mi) & " SN: " & M_D_SN(Mi) & " DeviceName: " & M_DName(Mi) & _
										" DeviceRoom: " & M_DRoom(Mi))
					Next
				Case "L:"
					ResponseL = Base64ToHex(Mid(Reply,Seperator(i)+1,Seperator(i+1)-Seperator(i)-2))
					If debug > 1 Then hs.WriteLog("Max_debug2", "L: lenght: " & CStr(ResponseL.length) & " L: response: " & ResponseL)
					Dim t As Integer = 1
					Dim L(Tcnt) As String
							Dim LLength as Integer
					Dim L_Pointer As Integer = 1
					Do until L_pointer > ResponseL.length
						LLength        = Val("&H" & Mid(ResponseL,L_Pointer,2))
						If LLength = 11                                             'Lenght = 11 means Thermostat
							L(t)           = Mid(ResponseL,L_Pointer,(LLength+1)*2)
							If debug > 1 Then hs.WriteLog("Max_debug2", "L: Device " & CStr(t) & ": " & L(t))
							Taddress(t)    = Hex2Dec(Mid(L(t),3,6))
							Temp           = Hex2Bin(Mid(L(t),11,2))                'convert byte 6 to binary status bits
							Tvalid(t)      = Mid(Temp,4,1)
							If Tvalid(t) = "0" Then TstatusT(t) = "invalid info"
							Terror(t)      = Mid(Temp,5,1)
							If Terror(t) = "1" Then Tstatus(t) += " error occurred"
							Tanswer(t)     = Mid(Temp,6,1)
							If Tanswer(t) = "1" Then TstatusT(t) += " not an answer to a Command"
							Tstatus(t)     = Mid(Temp,7,1)
							If Tstatus(t) = "0" Then TstatusT(t) += " not initialized"
							Temp           = Hex2Bin(Mid(L(t),13,2))                'convert byte 7 to binary status bits
							Tbattery(t)    = Mid(Temp,1,1)
							If Tbattery(t) = "1" Then TstatusT(t) += " low battery"
							Tlinkstatus(t) = Mid(Temp,2,1)
							If Tlinkstatus(t) = "1" Then TstatusT(t) += " link error"
							Tpanel(t)      = Mid(Temp,3,1)
							If Tpanel(t) = "1" Then TstatusT(t) += " panel locked"
							Tgateway(t)    = Mid(Temp,4,1)
							If Tgateway(t) = "0" Then TstatusT(t) += " gateway unknown"
							Tdts(t)        = Mid(Temp,5,1)
							If Tdts(t) = "0" Then TstatusT(t) += " DST inactive"
							If TstatusT(t) = "" Then TstatusT(t) = "OK"
							Tmode1(t)       = Mid(Temp,7,2)
							Select Case Tmode1(t)
								Case "00"
									'auto/week schedule
									Tmode2(t) = "Auto"
								Case "01"
									'Manual
									Tmode2(t) = "Manual"
								Case "10"
									'Party/Vacation
									Tmode2(t) = "Party/Vacation"
								Case "11"
									'Boost
									Tmode2(t) = "Boost"
								Case Else
									'something wrong'
							End Select
							Tvalve(t) = Val("&h" & Mid(L(t),15,2))                   ' current valve opening in %
							Ttemp(t) = Val("&h" & Mid(L(t),17,2)) / 2                ' Temperature setpoint
							Dim DateISThex As Double = Val("&h" & Mid(L(t),19,4))        ' date or Actual Temperature
							if Debug > 0 Then hs.WriteLog("Max_debug1","L: " & L(t) & " IST: " & DateISThex/10 & " Mode: " & Tmode1(t) & " HEX: " & Mid(L(t),19,4))
							If Tmode1(t) = "10"										' temporary Temp setting, =>Date
								Tdate(t) = DateSerial(2000 + (DateISThex And &h0F),((DateISThex And  &hE000) >> 12)+((DateISThex And &h80) >> 7),(DateISThex And &h1F00) >> 8)
								Ttime(t) = TimeSerial(Int(Val("&h" & Mid(L(t),23,2))/2),(Val("&h" & Mid(L(t),23,2))/2 - int(Val("&h" & Mid(L(t),23,2))/2))*60,0)
								TdateTime(t) = FormatDateTime(Tdate(t) & " " & Ttime(t))
								Tist(t) = "0"
							Else If DateISThex <> 0													' Actual Temperature
								Tist(t) = DateISThex/10
								TdateTime(t) = "--"
							Else
								TdateTime(t) = "--"
							End If
							If debug > 0 Then hs.WriteLog("Max_debug1","L: address: " & Taddress(t) & " tvalid: " & Tvalid(t) & " Terror: " & Terror(t)& " Tanswer:  " & Tanswer(t) & " mode: " & Tmode2(t) & " Valve: " & CStr(Tvalve(t)) & "% Temp: " & CStr(Ttemp(t)) & " date: " & TdateTime(t))
						Else
							If debug > 0 Then hs.WriteLog("Max_debug1","L: no Thermostat, Length L: command= " & LLength & "!")
						End If
						L_pointer     += (LLength+1)*2
						t += 1
					Loop
			Case "C:"
					ResponseC(dev) = Mid(Reply,Seperator(i)+1,Seperator(i+1)-Seperator(i)-2)
					Dim j1, j2, j3 As Integer
					Dim WP, WP2, WP3, WP4 As String
					Caddress(dev)   = Hex2Dec(hs.StringItem(ResponseC(dev),1,","))
					Temp            = Base64ToHex(hs.StringItem(ResponseC(dev),2,","))
					C_type(dev)     = Mid(Temp,9,2)
					C_SN(dev)       = hex2asc(Mid(Temp,17,20))
					If debug > 0 Then hs.WriteLog("Max_debug1", "C" & CStr(dev) & ": " & "address: " & Caddress(dev) & " type: " & C_type(dev) & " SerialNR: " & C_SN(dev))
					Select Case C_Type(dev)
						Case "00"
							' Cube
							If debug > 1 Then hs.WriteLog("Max_debug2", "C: C response: " & Temp)
							C_Cube_TV = Val("&h" & Trim(Mid(Temp,429,6)))
							C_Cube_WT = Hex2asc(Trim(Mid(Temp,429,10)))
							C_Cube_ST = Hex2asc(Trim(Mid(Temp,453,10)))
							If debug > 1 Then hs.WriteLog("Max_debug2", "C: C Cube response: " & C_Cube_WT & " " & C_Cube_ST)
						Case "01"
							' Thermostate
							C_Firmware(dev) = Hex2Dec(Mid(Temp,13,2))                      ' Firmware version
							C_Com_Temp(dev) = Val("&h" & Mid(Temp,37,2)) / 2               ' comfort temperature
							C_Eco_Temp(dev) = Val("&h" & Mid(Temp,39,2)) / 2               ' Eco Temperature
							C_Max_Temp(dev) = Val("&h" & Mid(Temp,41,2)) / 2               ' Max Temperature
							C_Min_Temp(dev) = Val("&h" & Mid(Temp,43,2)) / 2               ' Min Temperature
							C_Off_Temp(dev) = Val("&h" & Mid(Temp,45,2)) / 2 - 3.5         ' offset possible is -3,5 to 3,5 degrees, 3,5 = 0
							C_Win_Temp(dev) = Val("&h" & Mid(Temp,47,2)) / 2               ' window open temperature
							C_Win_Dura(dev) = Mid(Temp,49,2)                               ' window open duration
							C_Dur_Boos(dev) = Bin2Dec(Left(Hex2Bin(Mid(Temp,51,2)),3))     ' Boost duration
							If C_Dur_Boos(dev) = "7" Then C_Dur_Boos(dev) = "30"
							C_Val_Boos(dev) = Bin2Dec(Mid(Hex2Bin(Mid(Temp,51,2)),4,5))*5 & "%"    ' Boost Valve Value (%)
							C_Dti_deca(dev) = WeekdayName(Bin2Dec(Left(Hex2Bin(Mid(Temp,53,2)),3))+1,True,7) & " " & _
											Bin2Dec(Mid(Hex2Bin(Mid(Temp,53,2)),4,5)) & ":00u"   ' Decalcification: Day of week and Time
							C_max_Valv(dev) = Val("&h" & Mid(Temp,55,2))*100/255           ' Maximum Valve setting; *(100/255) to get in %
							C_off_Valv(dev) = Val("&h" & Mid(Temp,57,2))*100/255           ' Valve Offset ; *(100/255) to get in %
							For j1 = 1 To 7                                                ' days of the week
								WP = Mid(Temp, 7 + 52 * j1, 52)                            ' string with (13) values for the selected day
								C_Wk(j1)=""
								j2 = 1
								Do
									WP2 = Bin2Dec(Mid(Hex2Bin(Mid(WP,1+(j2-1)*4,4)),2,6))/2    ' temperature
									WP3 = Bin2Dec(Mid(Hex2Bin(Mid(WP,1+(j2-1)*4,4)),8,9))*5    ' time in minutes
									WP4 = FormatDateTime(TimeSerial(0,Wp3,0),4)                ' formatted time (in hours)
									C_Wk(j1) = C_Wk(j1) & "("&j2 & ") " & WP2 & "/" & WP4 & " "
									j2 += 1
								Loop until wp3 = "1440" Or j2 = 13
								If j1 = Weekday(Now(),7) Then C_Week(dev) = C_Wk(j1)           ' copy current day to C_Week() variable
								If debug > 0 Then hs.WriteLog("Max_debug1","C" & CStr(dev) & ": " & WeekdayName(J1,True,7) & " " & Weekday(Now(),7) & " " & C_Wk(j1))
							Next
							If debug > 0 Then hs.WriteLog("Max_debug1","C" & CStr(dev) & ": " & "ComT: " & C_Com_Temp(dev) & " EcoT: " & C_Eco_Temp(dev) & " MaxT: " & C_Max_Temp(dev) & " MinT: " & C_Min_Temp(dev) & " OffT: " & C_Off_Temp(dev) & " WinT: " & C_Win_Temp(dev) & " WinDur: " & C_Win_Dura(dev) & " Boostdur: " & C_Dur_Boos(dev) & " BoostVal: " & C_Val_Boos(dev) & " datetime_decal: " & C_Dti_deca(dev)&" Valve_Max: "&C_max_Valv(dev)& " Valve_off: "& C_off_Valv(dev) & " Firmware: "& C_Firmware(dev))
                                                Case "03" 'JK avoind unknown device message
                                                Case Else
                                                        ' unknown device
							hs.WriteLog("Error","Max Monitor; C" & CStr(dev) & ": " & " unknown device: " & C_Type(dev))
					End Select
					If debug > 1 Then hs.WriteLog("Max_debug2","C" & CStr(dev) & ": " & "response: " & Temp)
					dev +=1
				Case else
					hs.WriteLog("Error", "Max Monitor; unknown command: " &  CStr(dev) & Mid(Reply,Seperator(i)-1,2))
			End Select
		Next
		' all initial fields are read and processed
		' update all Max Devices. If MaxDevices don't exist, they will be created
		Dim dv, C1, C2, C3, CRef, Lref, Mref
		Dim DevTypeName, DevLocation2 As String
		If MaxCommand = ""							' If no MaxCommand then Check Setpoint setting via Listbox
			MaxCommand = "s:"
		End If
		Select Case MaxCommand
			Case "s:"
				Dim s_roomc2 As String
				Dim s_roomct As String = ""
				Dim s_roomct2 As String = ""
				Select Case s_mode                  ' check mode
					Case ""                         ' if mode = "" (Default) or "a" then 2 MSB = 00 (dec 0)
						s_mode = 0
					Case "a"                        ' if mode = "a" then 2 MSB = 00 (dec 0)
						s_mode = 0
					Case "p"                        ' if mode = "P" then 2 MSB = 01 (dec 64)
						s_mode = 64
					Case "t"                        ' if mode = "t" then 2 MSB = 10 (dec 128)
						s_mode = 128
					Case "b"                        ' if mode = "b" then 2 MSB = 11 (dec 192)
						s_mode = 192
						If Len(s_enddt) = 12 Then   ' if 12 then end date is given
							Tyy = Dec2Bin2(Val(Left(s_enddt,4))-2000,6)
							Tmm = Dec2Bin2(Val(Mid(s_enddt,5,2)),4)
							Tdd = Dec2Bin2(Val(Mid(s_enddt,7,2)),5)
							Tda = Dec2Hex(Bin2Dec(Left(Tmm,3) & Tdd & Right(Tmm,1) & "0" & Tyy),4)
							Thh = Dec2Hex(Val(Mid(s_enddt,9,2))*2 + Int(Val(Mid(s_enddt,9,2))/30),2)
						Else If Len(s_enddt) = 6 Then 'if 6 then given info is ddhhmm in the future
							Dim tempdaytime = ResponseH_Date
							tempdaytime = DateAdd("d",Val(Left(s_enddt,2)) ,tempdaytime)
							tempdaytime = DateAdd("h",Val(Mid(s_enddt,3,2)),tempdaytime)
							tempdaytime = DateAdd("n",Val(Mid(s_enddt,5,2)),tempdaytime)
							Tyy = Dec2Bin2( Year(tempdaytime)-2000,6)
							Tmm = Dec2Bin2(Month(tempdaytime),4)
							Tdd = Dec2Bin2(  Day(tempdaytime),5)
							Thh = Dec2Hex(Hour(tempdaytime)*2 + Int(Minute(tempdaytime)/30),2)
							If debug > 1 Then hs.WriteLog("Max_debug2","enddatetime: "& ResponseH_Date & " new " & tempdaytime)
						End If
						s_roomct2 = Tda & Thh
						If debug > 1 Then hs.WriteLog("Max_debug2", "s: date: " & Tda & " yy: " & Tyy & " mm: " & Tmm & " dd: " & Tdd & " tt: " & Thh)
					Case else
						hs.WriteLog("Error", "Max Monitor; wrong mode command: " &  s_mode)
				End Select
				Dim sc As Integer
				Dim s_loop_s As Integer
				Dim s_loop_e As Integer
				If s_room = 0 Then
					C1 = 1
					s_loop_s = 1
					s_loop_e = M_Rooms
				Else
					' lookup M response
					Mref = 1
					Do until s_room = M_Rnumber(Mref) Or Mref = M_Rooms
						Mref+=1
					Loop
					s_loop_s = Mref
					s_loop_e = Mref
				End if
				For sc = s_loop_s To s_loop_e						' loop all Thermostats
					C1 = sc
					Dim s_roomn As String = Dec2Hex(M_Raddress(C1),6) & Dec2Hex(M_Rnumber(C1),2)
					' lookup C response
					Cref = 1
					Do until Caddress(Cref) = M_Raddress(C1) Or Cref = Tcnt ' JK 100 -> Tcnt
						Cref+=1
					Loop
					' lookup L response
					Lref = 1
					Do until Taddress(Lref) = M_Daddress(C1) Or Lref = Tcnt ' JK 100 -> Tcnt
						Lref+=1
					Loop
					' write room name in ini file
					If hs.GetINISetting("Thermostat" & CStr(C1), "DeviceName", "", INI_FILE) <> M_DName(C1) Then hs.SaveINISetting("Thermostat" & CStr(C1), "DeviceName",M_DName(C1), INI_FILE)
					If debug > 0 Then hs.WriteLog("debugn4 s:", CStr(Cref) & Caddress(Cref) & C_Com_Temp(Cref))
					' look up & (encode room) command (temperature setting)
					If s_roomc = "auto" Or s_roomc = "00"
						s_roomC2 = "00"
					ElseIf LCase(s_roomc) = "com"
						s_roomc2 = Dec2Hex(C_Com_Temp(Cref) * 2 + s_mode,2)
					ElseIf LCase(s_roomc) = "eco"
						s_roomc2 = Dec2Hex(C_Eco_Temp(Cref) * 2 + s_mode,2)
					ElseIf LCase(s_roomc) = "win"
						s_roomc2 = Dec2Hex(C_Win_Temp(Cref) * 2 + s_mode,2)
        ElseIf LCase(s_roomc) = "temp" ' JK extra command
						s_roomc2 = Dec2Hex(Math.Round(hs.devicevalue("T2")/100,1) * 2 + s_mode,2) ' JK extra command (T@ holds the desired temperture in F*100
					ElseIf Val(s_roomc) < 31 And Val(s_roomc) > 4
						If debug > 0 Then hs.WriteLog("debugn4b s:", CDbl(s_roomc) )
						s_roomc2 = Dec2Hex(CDbl(s_roomc) * 2 + s_mode,2)
					ElseIf s_roomc = ""												'roomtemp per individual room temp setting (listbox)
						strDC = hs.GetINISetting("Thermostat" & CStr(C1), "FirstDeviceCode", "", INI_FILE)
						strDV = strHC & strDC+3
						If hs.devicevalue(strDV) <> hs.GetINISetting("Thermostat" & CStr(C1), "Settemp", "0", INI_FILE) Then
							hs.SaveINISetting("Thermostat" & CStr(C1), "Settemp",hs.devicevalue(strDV), INI_FILE)
							'If Ttemp(Lref) <> hs.devicevalue(strDV)/10 Then					'setpoint must be changed
								'hs.WriteLog("Max_debug0", "SetSetpoint, Thermostat" & CStr(C1) & " Current Setpoint: " & Ttemp(Lref) & " Required setpoint: " & strDV & " " & hs.devicevalue(strDV)/10) ' JK ???
								's_roomc2 = Dec2Hex(CDbl(hs.devicevalue(strDV)/10) * 2 + s_mode,2) ' JK ?????
								'Ttemp(Lref) = hs.devicevalue(strDV)/10
							'Else
								SetSetpoint = False
							'End If
						Else
							SetSetpoint = False
						End If
					Else
						hs.WriteLog("Error", "Max Monitor; unknown room command: " &  s_roomc)
					End If
					If SetSetpoint Then
						MaxCommand  = "000440000000"
						MaxCommand += s_roomn & s_roomc2 & s_roomct2
						If debug > 1 Then hs.WriteLog("Max_debug2","s: " & MaxCommand )
						'hs.WriteLog("Max_debug2","s: " & MaxCommand ) ' JK double writelog
						MaxCommand  = "s:" & HexToBase64(MaxCommand)
						SendString(NetStream, MaxCommand & vbCrLf)
						Reply = ReadString(Client)
						If debug > 1 Then hs.WriteLog("Max_debug2", "s: " & Reply)
						'hs.WriteLog("Max_debug2", "s: " & Reply) ' JK double writelog
					End If
					SetSetpoint = True
				Next
			Case ""
			Case Else
				hs.WriteLog("Error", "Max Monitor; unknown command: " &  MaxCommand)
		End Select
		'update all existing or create new
		strDC = hs.GetINISetting("Cube", "FirstDeviceCode", "", INI_FILE)
		If hs.DeviceExistsRef(strDV) = -1 Then                                ' check if Cube exist. if not, create devices
			DevTypeName    = hs.GetINISetting("Startup", "CubeName", "", INI_FILE)
			DevLocation2   = hs.GetINISetting("Cube", "DevLocation2", "", INI_FILE)
			For C1 = 1 To 2
				dv                 = hs.GetDeviceByRef(hs.NewDeviceRef(n1(C1)))
				dv.dc              = CStr(C1+ Int(strDC)-1)
				dv.hc              = strHC
				dv.can_dim         = False
						if DevLocsw
					dv.location        = DevLocation
					dv.location2       = DevLocation2
						else
					dv.location        = DevLocation2
				End If
				dv.dev_type_string = DevTypeName & "-" & CStr(ResponseH_SN) & "/" & CStr(ResponseH_Ad)& "/" & CStr(ResponseH_FW)
				dv.misc            = &h10
			Next
		End If
		' update Cube Device
		hs.SetDeviceValue(strHC & CStr(Int(strDC)+0),Val(ResponseH_Ye & ResponseH_Mo & ResponseH_Da))
		If Date_error_Mi > 10 Or Date_error_Mi < -10 Then
			hs.SetDeviceString(strHC & CStr(Int(strDC)+0),"<img src='/images/Off-Line.gif'> " & ResponseH_Date)
		Else
			hs.SetDeviceString(strHC & CStr(Int(strDC)+0),"<img src='/images/On-Line.gif'> " & ResponseH_Date)
		End If
		hs.SetDeviceValue(strHC & CStr(Int(strDC)+1),C_Cube_TV)
		hs.SetDeviceString(strHC & CStr(Int(strDC)+1),C_Cube_WT & "/" & C_Cube_ST)
		'thermostats
		For C2 = 1 To M_Devices                     'M_Devices holds the number of Thermostats
                  If M_Daddress(C2) <> "610272" ' JK address of the wall thermoste, just scip it.
			strDC = hs.GetINISetting("Thermostat" & CStr(C2), "FirstDeviceCode", "", INI_FILE)
			If strDC = "" Then hs.WriteLog("Error","Max Monitor; Thermostat setting in INI file incorrect")
			If hs.DeviceExistsRef(strDV) = -1 Then        ' check if Thermostat exist. if not, create devices
				hs.WriteLog("Max_debug0", "Create Radiator Thermostat Device: " & strDV)
				DevTypeName    = hs.GetINISetting("Startup", "ThermostatName", "", INI_FILE)
				'lookup M response Room
				Mref = 1
				Do until M_Raddress(Mref) = M_Daddress(C2) Or Mref = Tcnt ' JK 100 -> Tcnt
					Mref+=1
				Loop
				' lookup C response
				Cref = 1
				Do until Caddress(Cref) = M_Daddress(C2) Or Cref = Tcnt ' JK 100 -> Tcnt
					Cref+=1
				Loop
				hs.WriteLog("Max_debug1", "Firmware: " & C_Firmware(C2))
				'hs.WriteLog("Max_debug1", "Firmware: " & C_Firmware(C2)) ' JK double writelog
				DevLocation2 = M_RName(Mref)
				For C3 = 1 To 5
					dv                 = hs.GetDeviceByRef(hs.NewDeviceRef(n2(C3)))
					dv.dc              = CStr(C3+ Int(strDC)-1)
					dv.hc              = strHC
					dv.can_dim         = False
							if DevLocsw
							else
					End If
					dv.dev_type_string = DevTypeName & "-" & CStr(M_D_SN(Mref)) & "/" & CStr(M_Daddress(Mref)) & "/" & CStr(C_Firmware(Cref)) & "/" & CStr(M_DRoom(Mref))
					dv.misc            = &h10
					If C3 = 4 Then						'create listbox
						hs.DeviceValuesAdd(strHC & CStr(C3+ Int(strDC)-1), _
						"OFF" & chr(2) & "45" & chr(1) & _
						"12.0" & chr(2) & "120" & chr(1) & _
						"13.0" & chr(2) & "130" & chr(1) & _
						"14.0" & chr(2) & "140" & chr(1) & _
						"15.0" & chr(2) & "150" & chr(1) & _
						"16.0" & chr(2) & "160" & chr(1) & _
						"17.0" & chr(2) & "170" & chr(1) & _
						"18.0" & chr(2) & "180" & chr(1) & _
						"18.5" & chr(2) & "185" & chr(1) & _
						"19.0" & chr(2) & "190" & chr(1) & _
						"19.5" & chr(2) & "195" & chr(1) & _
						"20.0" & chr(2) & "200" & chr(1) & _
						"20.5" & chr(2) & "205" & chr(1) & _
						"21.0" & chr(2) & "210" & chr(1) & _
						"21.5" & chr(2) & "215" & chr(1) & _
						"22.0" & chr(2) & "220" & chr(1) & _
						"22.5" & chr(2) & "225" & chr(1) & _
						"23.0" & chr(2) & "230" & chr(1) & _
						"23.5" & chr(2) & "235" & chr(1) & _
						"24.0" & chr(2) & "240" & chr(1) & _
						"24.5" & chr(2) & "245" & chr(1) & _
						"25.0" & chr(2) & "250" & chr(1) & _
						"ON" & chr(2) & "300" & chr(1) & _
						"Any Value" & chr(2) & "999", true)
					End If
					If Debug > -1 Then hs.WriteLog("Max_debug0", "dev: " & n2(C3))
				Next
			End If
			'update Thermostats
			' lookup C response
			Cref = 1
				Cref+=1
			Loop
			Dim Temps As String
			If C_Off_Temp(Cref) = 0 Then
				Temps = "C" & CStr(C_Com_Temp(Cref)) & " E" & C_Eco_Temp(Cref) & " W" & C_Win_Temp(Cref) & " +" & CStr(C_Max_Temp(Cref)) & " -" & C_Min_Temp(Cref)
			Else
				Temps = "C" & CStr(C_Com_Temp(Cref)) & " E" & C_Eco_Temp(Cref) & " W" & C_Win_Temp(Cref) & " +" & CStr(C_Max_Temp(Cref)) & " -" & C_Min_Temp(Cref) & " O" & C_Off_Temp(Cref)
			End If
			hs.SetDeviceValue(strHC & CStr(Int(strDC)+0),C_Off_Temp(Cref)*10)  ' Offset Temperatrue
			hs.SetDeviceString(strHC & CStr(Int(strDC)+0),Temps)
			dv2 = hs.GetDeviceByRef(hs.GetDeviceRef(strHC & CStr(Int(strDC)+0)))
			IF HideTemps Then
				dv2.misc = (dv2.misc OR &H20)
			Else
				dv2.misc = (dv2.misc AND (NOT &H20))
			End If
			hs.SetDeviceValue(strHC & CStr(Int(strDC)+2),Weekday(Now(),7))       'Auto Day schedule
			hs.SetDeviceString(strHC & CStr(Int(strDC)+2),C_Week(Cref))
			' lookup L response
			Lref = 1
			Do until Taddress(Lref) = M_Daddress(C2) Or Lref = Tcnt ' JK 100 -> Tcnt
				Lref+=1
			Loop
			If instr(hs.DeviceString(strHC & CStr(Int(strDC)+1)),TstatusT(Lref)) = 0 Then hs.SetDeviceLastChange(strHC & CStr(Int(strDC)+1),now)
				dv2 = hs.GetDeviceByRef(hs.GetDeviceRef(strHC & CStr(Int(strDC)+1)))
				If TstatusT(Lref) = "OK" Then
				hs.SetDeviceValue(strHC & CStr(Int(strDC)+1),2)  ' Status ok
				hs.SetDeviceString(strHC & CStr(Int(strDC)+1),"<img src='/images/On-Line.gif'> " & TstatusT(Lref))
				IF HideStatusOK Then dv2.misc = (dv2.misc OR &H20)
			Else
				hs.SetDeviceValue(strHC & CStr(Int(strDC)+1),1)  ' Status error
				hs.SetDeviceString(strHC & CStr(Int(strDC)+1),"<img src='/images/Off-Line.gif'> " & TstatusT(Lref))
				IF HideStatusOK Then dv2.misc = (dv2.misc AND (NOT &H20))
			End If
			hs.SetDeviceValue(strHC & CStr(Int(strDC)+3), Ttemp(Lref)*10)     'Setpoint * 10
			hs.SetDeviceString(strHC & CStr(Int(strDC)+3),"<img src='/images/Temperatures/" & CStr(Int(Ttemp(Lref))) & ".gif'> " & Tmode2(Lref)&"/"&CStr(Ttemp(Lref))&"/"&CStr(TValve(Lref))&"/"&TdateTime(Lref))
			If Tist(Lref) <> "" Then
				hs.SetDeviceValue(strHC & CStr(Int(strDC)+4), Tist(Lref)*10 - hs.DeviceValue(strHC & CStr(Int(strDC)+0)))     'Current Temperature * 10
				hs.SetDeviceString(strHC & CStr(Int(strDC)+4),"<img src='/images/Temperatures/" & CStr(Int(Tist(Lref) - hs.DeviceValue(strHC & CStr(Int(strDC)+0))/10)) & ".gif'> " & Tist(Lref) - hs.DeviceValue(strHC & CStr(Int(strDC)+0))/10)
			End If
                  End If  ' JK skip of unwanted devices
		Next
		' Disconnect at the end
		Client.Close()
	Catch ex As Exception
		If ex.Message = "De index ligt buiten de matrixgrenzen." Then
			hs.WriteLog("Error","Max Monitor: " & ex.Message & " You probably need to increase the WaitSec value in the .ini file.")
		Else
			hs.WriteLog("Error","Max Monitor: " & ex.Message)
		End If
	End Try
End Sub
Private Function ReadString(ByVal Client As System.Net.Sockets.TcpClient) As String
	Dim Stream As NetworkStream = Client.GetStream
	Dim Buffersize As Integer = Client.ReceiveBufferSize
	Dim Data(Buffersize -1) As Byte
	If Stream.CanTimeout Then
		Stream.ReadTimeout = 1000 * 15
	End If
	Dim BytesRead As Integer = Stream.Read(Data, 0, Buffersize)
	Return Encoding.ASCII.GetString(Data, 0, BytesRead)
End Function
Private Function SendString(ByVal Stream As NetworkStream, ByVal Data As String) As Boolean
	Dim Bytes As [Byte]() = Encoding.ASCII.GetBytes(Data)
		Stream.WriteTimeout = 1000 * 5
	End If
	Stream.Write(Bytes, 0, Bytes.Length)
	Return True
End Function
Private Function Base64ToHex(base64string As String) As String
	Dim result As String
	Dim b64bytes() As Byte = System.Convert.FromBase64String(base64string)
	For Each b As Byte In b64bytes
		result &= Hex(b).PadLeft(2, "0"c)
	Next
	Return result
End Function
Private Function HexToBase64(ByVal HexText As String) As String
	Dim HexTextBytes As Integer = HexText.Length \ 2 -1
	Dim result(HexTextBytes) As Byte
	Dim i As Integer
	For i = 0 To HexTextBytes
		result(i) = Convert.ToByte(HexText.Substring(i * 2, 2), 16)
	Next
	Return Convert.ToBase64String(result)
End Function
Private Function Hex2Bin(ByVal dwHex As String) As String
	dwHex = CStr(dwHex)
	Dim sTemp As String
	Dim I As Integer
	For I = 1 To Len(dwHex)
		sTemp = Mid(dwHex, I, 1)
		Select Case sTemp
			Case "0": Hex2Bin = Hex2Bin & "0000"
			Case "1": Hex2Bin = Hex2Bin & "0001"
			Case "2": Hex2Bin = Hex2Bin & "0010"
			Case "3": Hex2Bin = Hex2Bin & "0011"
			Case "4": Hex2Bin = Hex2Bin & "0100"
			Case "5": Hex2Bin = Hex2Bin & "0101"
			Case "6": Hex2Bin = Hex2Bin & "0110"
			Case "7": Hex2Bin = Hex2Bin & "0111"
			Case "8": Hex2Bin = Hex2Bin & "1000"
			Case "9": Hex2Bin = Hex2Bin & "1001"
			Case "A": Hex2Bin = Hex2Bin & "1010"
			Case "B": Hex2Bin = Hex2Bin & "1011"
			Case "C": Hex2Bin = Hex2Bin & "1100"
			Case "D": Hex2Bin = Hex2Bin & "1101"
			Case "E": Hex2Bin = Hex2Bin & "1110"
			Case "F": Hex2Bin = Hex2Bin & "1111"
		End Select
	Next I
End Function
Private Function Hex2Dec(Hextext As String) As String
	Dim result As String = Convert.ToInt32(Hextext,16)
	Return result
End Function
Private Function Hex2asc(Hextext As String) As String
	Dim i As Integer
	For i = 0 To HexText.Length \ 2 -1
		result &= Chr(Val("&h" & Mid(HexText,i*2+1,2)))
	Next
	Return result
End Function
Private Function Bin2Dec(Binary As String) As long
	Dim result As Long
	Dim s As Integer
	For s = 1 To Len(Binary)
		result += (Mid(Binary, Len(Binary) - s + 1, 1) * (2 ^ (s - 1)))
	Next s
	Return result
End Function
Private Function Dec2Bin(DecimalNum As Long) As String
	Dim tmp As String
	Dim n As Long
	n = DecimalNum
	tmp = Trim(Str(n Mod 2))
	n = n \ 2
	Do While n <> 0
		tmp = Trim(Str(n Mod 2)) & tmp
		n = n \ 2
	Loop
	Return tmp
End Function
' function which converts dec value into bin (string) left padded with 0 upto length
Private Function Dec2Bin2(DecimalNum As Long, length As Integer) As String
	Dim n As Long
	n = DecimalNum
	result = Trim(Str(n Mod 2))
	n = n \ 2
	Do While n <> 0
		result = Trim(Str(n Mod 2)) & result
		n = n \ 2
	Loop
	Dim lgth As Integer = Len(result)
	Dim m As Integer
	For m = 1 To length - lgth
		result = "0" & result
	Next
	Return result
End Function
' function which converts dec value into hex (string) left padded with 0 upto length
Private Function Dec2Hex(Dec As Integer, length As Integer) As String
	Dim n As Integer
	result = Hex(Dec)
	For n = 1 To length - lgth
	Next
	Return result
End Function
labtec
Post by labtec »
I replaced the script files for the newest version (config file, vb script file) and edit the right settings in the
config file (IP-adres, housecode). After the restart of HS2 I don't see any ELV MAX! devices at all in my device
list. What could be wrong? How do I get my ELV MAX! devices back :?:
PuNiSHeR
Post by PuNiSHeR »
Is that you have properly removed your old devices?
Is that you have an error line in Homeseer?
Is that you have closed your MAX! application ?
labtec
Post by labtec »
PuNiSHeR wrote:Hello,
Yes I have removed the old devices
I don't have an error line
MAX! application?
The problem is that I don't see any devices after running the script.
jayeazy
Post by jayeazy »
Just installed the script in my new HS3 setup, got some weird issues...
There seem to be some items not set correctly, for instance,
- i'm missing one room in the devices.......and got one device with no name
- setpoint Temp are not displayed with right device, some how they got mixed up....Temp for Living is set to kitchen etc....
Any one else has this problem ?
Q?:
Does it need the MAX.db file which is pointed in the ini, just copied it from the HS2 setup, and linked to it......
Jay
Meden199
Post by Meden199 »
I have also installed the script.
My homeseer detects the thermostat but in the log there is an error:
Evertime the script runs, I see in the log the following error:
~!~Error~!~Max Monitor; C2: unknown device: 02
I have only a cube and ond thermostat in the living room.
Any suggestions?
JoopK
Post by JoopK »
My scipts is still working on HS2. But when I connect to the device useing the MAX! link all devices are gone?
I had it in the past and I just set all devices again into learning mode. But stil it is strange that everything is still in the cube, but not accesable anymore via their own interface?
The only thing is that I have a additional messange that C1 is a not existing decive, for the rest it is still working....
Fischi
Post by Fischi »
I'm still using Bernard's script 02 l and MAX! software 1.3.4. for a few years.
Often my cube looses the radiator thermostats and it's not very comfortable to learn as new everytime.
So I want to update my software to the latest 1. 4.xx - hoping the cube don't forget the learned thermostats anymore.
Does anybody have tried this latest MAX! version and Bernard's script 02 p ?
Please tell me what your experiences are because I'm a little bit afraid to update whitout the knowledge if it works for you.
Fischi
mhn
Post by mhn »
I use one of these scripst with firmware 1.4. It's stable in use. Newer had problems once installed. I had a lot of problems at start. The script don't like my MAX walls.
Regards
Morten
Fischi
Post by Fischi »
Thanks Morton,
have you tested it with v. 02l and 02p ?
Did you ever have lost radiator thermostats by the MAX! cube ?
Regards, Fischi
