Has anyone tried to adjust the memory settings of the albatron? Under system / memory there is a slider that divides the memory between program and memory usage. It's now at the far left (which gives negative memory btw), but when I attempt to slide it, it goes to the far right leaving no memory for programs.
I think the slow running of the tablet might have something to do with the inproper allocation of memory. So I am trying to change it.
Also a problem is the calibration. My touchscreen is off with a couple of mm to the left. When I try to calibrate it won't accept any new settings. Kinda irritating because the scrollbar on the browser cannot be clicked on but it will use the far right of the page which is usually an add. And since the albatron does not have hardware buttons to scroll this is irritating.
Anyone have these problems too?
Albatron - Memory and Calibration?
On most PocketPC's this option was removed from version 2003
Change is having no effect.
For better performance we need more memory in the cache (GDI, file etc)
http://www.pocketpc-live.com/pocket-pc/ ... et-pc.html
@Chak: Which program do you use to get into the registry of the albatron?
