I am seaching for a touchscreen for my HC. I want it to be 7" till 12". Now i see there are a lot of technics. what is the best technic and why?
- Resistive touchscreens
- Surface acoustic wave (SAW) touchscreens
- Capactive touchscreens
- and more
Maybe somebody also knows where i can get one (Holland)
Thank you
Best Touchscreen technique for my Home Control
- Snelvuur
I would start off at http://en.wikipedia.org/wiki/Touchscreen and then use the search button, there are tons of items about touchscreen with certain functions. All depends also what you want. Do you want a screen which can also run stuff? (embedded) or does it only needs to be a touchscreen. Or do you want to build it into the wall, or is it ok if it sticks out a bit?
Yes, i already read wiki. But maybe somebody could tell me what is the best technic to use for a HC.
I don't know if i want it to be build in, or just a screen, or with pc incl. Its just the technic of the screen.
its ok if it sticks out (a little) when i am going to make the choice to build it in.
