small barabone pc
Forum about all kind of Touchpanels & Displays.
small barabone pc
Postby Harry » Sun Jan 17, 2010 1:10 pm
can a small pc like this
http://www.abgcomputers.nl/Mini_PC_(barebone).php
connected to a touchscreen run homeseer touch ?? :?:
or is it better to use a asus eee or so
Postby TANE » Sun Jan 17, 2010 1:45 pm
If you can install windows xp on this machine it will run There is also a XPe version maybe it will run on that. Other option is go for a umpc or the asus eee top
Re: small barabone pc
Postby Harry » Mon May 10, 2010 11:47 am
still looking for an small server pc to run homeseer on, and stil not sure what to buy.
i am thinking about a a atom 330 or so .
but i need more then 1 serial port.
i have an pci expansion card for two additional serials.
can a atom 330 do the job.
as OS it has to run windows 2003 server.
Small pc
Postby Verkenner » Mon May 10, 2010 3:30 pm
Hi Harry, see here:
viewtopic.php?f=8&t=4760
Grtz, Verkenner
Best regards, Verkenner
Verkenner
Postby simjoc » Tue May 11, 2010 4:21 am
Hi Harry,
Another option is to buy the Zotac NM10-ITX WiFi. (http://www.alternate.nl/html/product/Mo ... ocket+Atom)
This board is a bit more expensive but has more options than the Asus.
You can look for a pci-X Com port extension. (http://www.cooldrives.com/4pciexsecars.html)
Gr Simjoc
simjoc
Barebone pc with 2 serial ports
Postby Verkenner » Tue May 11, 2010 6:31 pm
Or this one ( now only 18$ ) PCI 2-Port Serial (RS232) I/O Controller Card
http://www.cooldrives.com/spprpci2sdu2.html
Grtz. Verkenner
Verkenner
Return to Touchpanels, Displays & UMPC devices.
cron
