USB to VGA?
Forum about all kind of Touchpanels & Displays.
USB to VGA?
Postby Francois » Fri Sep 09, 2011 2:35 pm
I was wondering if any one has experience with the following setup:
- Virtualized (Hyper-V) client running HS Touch (no problems to be expected here)
- USB ports exposed through a Belkin USB network HUB ( this works fine, I am using it now for over 2 years)
- VGA Touchscreen connected to a VGA to USB connector like this one: http://www.dealextreme.com/p/usb-2-0-to ... reen-34756
The thing that worries me the most is: will the USB hub be able to support the required throughput that comes with VGA.
Anyone ever tried this before?
Francois
Francois
Francois
Re: USB to VGA?
Postby DJF3 » Sat Sep 10, 2011 1:00 pm
You might find more information here: domoticaforum.eu/viewtopic.php?f=49& ... kin#p37894
DJF3
Re: USB to VGA?
Postby Francois » Mon Sep 12, 2011 10:57 am
Thx!
Mixed replies. Envers test indicates it works with the Belkin hub ( the one I have) but other tests shopw diferent results, possibly because of the type of USB port (1.1 instead of 2.0).
The belkin network hub supports 5-USB2.0 ports so this looks promissing. I think I'll just give it a go and order a USB to VGA adpater from ebay or deal extreme. They are cheap and it is worth the experiment. I'll post my reveiw results here.
Thanks
Francois
Francois
Return to Touchpanels, Displays & UMPC devices.
cron
