does anyone tried HomeSeer Z-NET Remote Z-Wave Interface
Edwin2008
Post by Edwin2008 »
It looks like a simple solution to get a z-wave adapter n the network instead of via USB for acceptable price (considering the use of a raspberry pi)
Wonder if it would be possible to run HS on the device
** edwin **
Akatar
Re: does anyone tried HomeSeer Z-NET Remote Z-Wave Interface
Post by Akatar »
i use 2 of those, but i am running hs3 on a server not on the device itself
Sparkman
Post by Sparkman »
The HomeSeer Zee S2 is basically that. It imcludes the same hardware zwave interface and has HS3 preinstalled. Note that the version of HS3 that it comes with is limited to 5 plugins. You could build your own as well with a Raspberry Pi and a Razberry zwave interface.
Sent from my Phone using Tapatalk
Edwin2008
Post by Edwin2008 »
Up until know i'm using HS2 with a Aeon S2 stick on a Silex USB server. sofar working alright but now i'm trieng to get a Quibino 0-10V working with HS 2 and that is failing. HS2 import's the Quibino but i'm unable to control it via HS, just no respons.
So i'm wondering if i should upgrade to a zwave+ dongle and at that moment i found the Z-NET and that would also eliminate the silex USB driver. One thing less that could disrupt the process.
With the z-net. Do i need to get the z-net competently next to the z-wave device for pairing or is it possible to just use the usb stick of the z-net?
For the remark on building my own pi etc. Bit over my head and bit to time consuming at the moment.
** edwin **
Akatar
Post by Akatar »
You need the znet for pairing, i have 2 units with 2 zwave networks. i have to pair it with that unit who is going to control the device.
Edwin2008
Post by Edwin2008 »
eh, you mean the two devices do not interchange data of the clients?
** edwin **
Akatar
Post by Akatar »
not on my setup, i did chose for 2 seperate zwave networks
Bastiaan
Post by Bastiaan »
There Seems no way to connect them. 3 sets here and to be honest working flawless for years.
Phaeton
Post by Phaeton »
The qubino might not work since you use hs2. You could install a trial of hs3 and see if it works then.
groeten,
Edwin2008
Post by Edwin2008 »
It's either hs2 or the zwave dongle. It s2 so no zwave plus
** edwin **
Edwin2008
Post by Edwin2008 »
tried HS3 trial with S2 stick, not woring alright. Not all devices usable in HS3. Quibino totally not even show. Think it has somethingto do with stick. Very much in doubt z-net or usb stick. If going for stick which one would be the best choice?
** edwin **
Akatar
Post by Akatar »
is it a aeonlabs stick?
try to update youre stick
Edwin2008
Post by Edwin2008 »
Hm, not aware that it was possible. Will look into that option.
** edwin **
Return to “Z-Wave Forum”
