Connecting Qubino Dimmer (0-10v) to Buva ventilation unit
Postby Sander_ » Mon Jul 31, 2017 7:52 pm
Hello all,
Last week I bought a Qubino Flush Dimmer 0-10v, type ZMNHVD1. I want to use it to remotely control our home ventilation unit, a Buva Boxstream+.
Currently the unit is controlled via a main control in the living room (Buva Vital Air System). If possible, I'd still like to use that unit as well but it is not a mandatory requirement.
My skills in electronic schematics are not that great, so I made a drawing of how I think I should connect it. Many people have already done this I believe from what I found on the net so far, however I couldn't find a schema on how to do it.
Please have a look at it here, click for a bigger picture:
Wiring coming in from the bottom part of the drawing, are the wires coming from the main control unit. 12v, GND and 0-10v. They are currently connected to the circuit board in the unit.
My questions:
- Is my schema correct?
- Can I split the 12 volt wire to both feed the Qubino and the Buva?
- Can I split the GND wire, to both connect the Qubino and the Buva?
Sander_
Re: Connecting Qubino Dimmer (0-10v) to Buva ventilation unit
Postby raymonvdm » Tue Aug 01, 2017 1:24 pm
The connector on the Buva has a 12volt output and ground to feed your Qubino. (Some sort of Remote Control connector) so you only need to connect the Qubino and you`re done :D (as far is i can see)
raymonvdm
Postby Sander_ » Tue Aug 01, 2017 2:35 pm
raymonvdm wrote:The connector on the Buva has a 12volt output and ground to feed your Qubino. (Some sort of Remote Control connector) so you only need to connect the Qubino and you`re done :D (as far is i can see)
Woops, I thought of it the other way around...! Now it is really easy, thank you!
Sander_
Postby Sander_ » Tue Aug 01, 2017 5:26 pm
One more question, do I need to connect the GND to both the power input GND and the 0-10v input GND on the Qubino?
Sander_
Postby raymonvdm » Thu Aug 03, 2017 11:22 am
I think you need to connect the:
- GND to the - of the Qubino
- 12V to the + of the Qubino
- 0-10V to the A0 of the Qubino (the 0-10V output pin)
And then perform some testing :D
raymonvdm
Postby Sander_ » Fri Aug 04, 2017 2:11 pm
Already got it hooked up, but my replies on this forum show up late because they need to be approved first :)
I 'dared' to connect the wires already, it's working great! It responds really nice and quick.
Thanks for the initial hint raymonvdm, that made it instantly clear.
Sander_
Postby teunaldo » Mon Jun 08, 2020 12:10 am
I use this solution with the KaKu 0-10v dimmer.
However.. I notice issues on the 433mhz because some traffic never arrives the dimmer.
I would love to use the Qubino, but I have 2 questions about this:
1. Is there a Zigbee alternative dimmer to use?
2. Is it possible to connect the Qubino to Toon Thermostat and use it in HomeAssistant?
Thanks in advance,
teunaldo
Return to Z-Wave Forum
