I try to install open-Zwave with Aeon Labs Stick S2 on my pcduino
I have already manage to run domotiga...
http://www.domoticaforum.eu/viewtopic.php?t=8853#p73507
Now I will pass to the next step and first I want control a light with zwave...
So I follow the instructions of the wiki page domotiga.nl/projects/domotiga/wiki/Z-Wa ... _OpenZWave
First "problem" in step 1. Building open-zwave:
the link http://open-zwave.googlecode.com/svn/trunk/ is wrong and I need to go on github https://github.com/OpenZWave/open-zwave and unzip the files in /open-zwave-read-only
After the command $ make seems work fine... (I'm far to be an expert of linux)
Now the step 2. Building DomoZWave wrapper...
$ cd ~/domotiga/wrappers/domozwave
$ ln -s ~/install/open-zwave-read-only ./open-zwave
$ make clean
$ make
ubuntu@ubuntu:~/install/domotiga/wrappers/domozwave$ make clean
rm -f libdomozwave.so DomoZWave.o
open-zwave library cannot be found at "open-zwave/*.a", did you compile it?
make: *** [defs] Error 1
I'm stuck on this problem for a while ... help please
