Fibaro FGBS321 Universal Binary Sensor
Re: Fibaro FGBS321 Universal Binary Sensor
Postby Akatar » Fri Oct 23, 2015 3:54 pm
Antoon wrote:Mine Amazone with firmware 2.1 does the following
Input 1 is does nothing in HS3 but the output is working, also in HS3
Input 2 is working in HS3 and also the output.
same here,
tried different ubs modules, but here are people with both inputs working, so what is different?
Akatar
Postby Antoon » Sun Oct 25, 2015 11:15 am
I deleted the device completely from HS
Did a new import.
Now it has swap the problem.
Input 1 is working 100% and input 2 only the output :shock:
- Antoon
Antoon
Postby Bastiaan » Sun Oct 25, 2015 11:44 am
could it be the fact that I also connected a temp sensor that made both work?
Bastiaan
Postby Bastiaan » Sun Oct 25, 2015 1:19 pm
OK did some more testing:
Fresh print connected without temp sensor, does give the inputs but none worked.
Added a temp sensor, removed the device and added it again. Then the temp reading shows up but only one input worked.
Went back to the first ones I tested and worked fine before, now also only one input works. Strange things happening.
The association seem to be added fine, endpoint 1 and 2 are added to HS and with the temp sensor it also adds group 3 to HS.
FW version is equal on all. (2.1)
My HS: 30.208 with the latest 1.41 Zwave plugin.
Tested with Z-net boxes.
Bastiaan
Postby Antoon » Sun Oct 25, 2015 1:52 pm
Bastiaan,
I though also maybe it has to do something with the temp sensor.
So I connect a temp sensor to it and import the sensor again.
Same problem as before, and I have no temp sensor, only four devices.
I am also on HS .208 and my Z-wave is .39
There are some people on the HS board that have it working, but it looks like they have import it with a older Z-wave version
- Antoon
Antoon
Previous
Return to Z-Wave Forum
