Procedure: z-wave devices to new HS installation
DJF3
Post by DJF3 »
Team,
I had setup a test HS3 system (with Aeon Gen-5 stick) and Fibaro z-wave devices.
That worked fine.
Now I have setup a new server, new OS, fresh HS3 installation on the exact same hardware and want to "move" the z-wave devices over.
Q: Is there a specific procedure to do this?
Thought that an "import z-wave devices" in the new setup was enough, but that only imported the root devices without the child devices.
To make it work I had to re-learn each device..
Akatar
Re: Procedure: z-wave devices to new HS installation
Post by Akatar »
full rescan did not work?
DJF3
Post by DJF3 »
No.. will do some more testing!
Return to “Z-Wave Forum”
