Z-wave replacement for Marmitek Universal Module?
Postby WfromL » Thu Aug 27, 2015 11:52 am
I'm trying to switch from X10 to Z-wave. I have several Marmitek Universal Modules UM7206, which basically provide a potential-free Open/Closed contact. This contact can be either momentarily (few seconds) or permanent.(This module also gives a nice loud beep when activated, but I can live without that).
Looks very simple,but I cannot figure out how to do that with Z-wave. Any suggestions?
WfromL
Re: Z-wave replacement for Marmitek Universal Module?
Postby John » Fri Aug 28, 2015 8:41 am
Have a look at the universal binary sensor of Fibaro
John
Verzonden vanaf mijn iPhone met behulp van Tapatalk
John
Postby stefxx » Fri Aug 28, 2015 5:40 pm
Qubino Flush 1D Relay?
stefxx
Postby WfromL » Fri Aug 28, 2015 7:49 pm
Thanks for the suggestions.
If I understand it correctly the Qubino relay switches 220 Volt ON/OFF and what I need is a voltage free ON/OFF contact. I could of course use the Qubino output to switch an ordinary relais but that's one more component that can fail, and it's not very elegant.
The Fibaro binary sensor could do the job, I think I'll try that one.
WfromL
Postby stefxx » Sat Aug 29, 2015 11:12 pm
The Qubino 1D relay also does voltage free on/off. Otherwise I would not have suggested it :)
stefxx
Postby WfromL » Sun Aug 30, 2015 6:44 pm
Well, I said "if I understand it correctly" :) So thanks for correcting me Stefxx.
I trusted the Robbshop website where it says: "De qubino modules schakelen altijd de aangesloten spanning (220V). Fibaro z-wave modules kunnen ook spanningsvrij schakelen".
I did some more google searches and it appears this information is indeed incorrect.
WfromL
Postby WfromL » Wed Sep 09, 2015 12:51 pm
Update:
I ordered the Qubino Flush 1D . Works fine right out of the box.
I guess the Fibaro binary sensor could have done the job as well, but it needs an extra DC power supply which for me was less convenient.
Thanks again for pointing me in the right direction.
WfromL
Postby stefxx » Wed Sep 09, 2015 4:18 pm
Great, thanks for reporting back to us!
stefxx
Return to Z-Wave Forum
cron
