Merten Implus Relais Switch
abl
Post by abl »
I'm currently replacing my last non-zwave switches. These are part of a 'hotel-switch' (hotelschakeling). The electrician could not get get a full working solution as I would need 'puls relais' or
'time relais' switches (instead of the Merten relais switch that I have now, which is the 576897 version schneider-electric.com/en/product/MTN57 ... 0-1000-va/ ).
I searched quite extensively but could not find a puls or time relais version. Could someone help me out if these exist at all or whether I should look for a different solution?
abl
Re: Merten Implus Relais Switch
Post by abl »
Had several interactions with different people about these switches and apparently there are no solutions of Merten Connect.
Instead there was one suggestion to use the following combination:
- Merten normal impulsswitch (MTN3150-0000) and a normal button
- Qubino or Fibaro module
Anyone an idea whether that would that work in my situation?
Return to “Z-Wave Forum”
