Merten Connect
EzHome
Merten Connect
Post by EzHome »
I just tested Network Health Options with the Aeon-Labs Z-Stick and it works in HS.
Both your Merten and ACT are routers, the router function is automatic in a z-wave network.
My HS is upstairs and some devices are in the basement, they work great with routers on the first floor installed.
Alexander
Merten Connect
Post by Alexander »
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by ezHome</i>
not all devices work as a router, normaly all z-wave switches work as a router.<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Can you update the website with this information? Currently the Popp devices are all mentioned as "slave". So, is for example the Adaptus also a router?
Nice 2 see that you also included Merten in your portfolio.
EzHome
Merten Connect
Post by EzHome »
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by mgizmo</i>
<br /><blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by ezHome</i>
There is no need to update the information because it's correct, Master / Slave isn't the same as router or no router.
In general power line connected devices work as router, all battery operated devices are no routers.
Master means it can send z-wave signals and slave means it receives.
But to keep it clear I added extra information if the product is a router or not.
So your question if the Popp Adaptus is a router is yes and it also is a slave.
William.abbo
Merten Connect
Post by William.abbo »
O.k., so it look's like the Aeon-Labs Z-Stick is a good investment ezHome, the Network Health Options do work with this stick, I will order one this week. In the mean time I have made a little changes to my test environment to see wether routing is working properly now. For now I do not see any 'warning' messages' in the HS log any more. ezHome thanks for the info.
William.abbo
Merten Connect
FYI:
Replaced the Merten RF-receiver 507001 with a different Z-Wave module for testing puposes, all routing problems are gone! So it seems that a Merten RF-receiver 507001 does NOT route.
EzHome
Merten Connect
Post by EzHome »
Strange because the the catalog says it's a router:
http://www.merten.de/download/DL_kat_nl ... ysteem.pdf
William.abbo
Merten Connect
Mmm, I see, obviously not.
<br />Strange because the the catalog says it's a router:
Return to “Z-Wave Forum”
