Danfoss Zwave radiator valve Review [Dutch/English]
Postby Peter Meuris » Sat Oct 31, 2009 9:24 am
Question: If you turn the radiator knob. Will the radiator valve immediately report that to the zwave base station ?
Peter Meuris
Postby TANE » Sat Oct 31, 2009 9:31 am
Danfoss will report that direct.
You have to push the control button
There is no need for turning off
Twitter http://twitter.com/Chak64%20My%20Domotica%20Log%20www.tane.nl/wp</font id="size1">
Postby mhn » Sat Oct 31, 2009 9:44 am
The Danfoss only report changes from sun to moon symbol or the other way (when the control button is pushed.). It will not report changes done with the knob.
The thermostat has a mechanical part with the knob, and a Z-wave part attached that control the sun/moon symbols.
mhn
Postby Peter Meuris » Sat Oct 31, 2009 10:28 am
To put it straight.
If i change the knob, and then push the control button on the DANFOSS, the signal is sent ?
Is this right ?
Peter Meuris
Postby EzHome » Sat Oct 31, 2009 10:31 am
That is correct but there is no need to turn the knob, it sends it's status after pushing the day / night button.
EzHome
Postby mhn » Sat Oct 31, 2009 10:34 am
It is 2 different systems.
The knob works as a normal thermostat, and the control button takes it down around 3 degrees from where the knob is set.
So nothing will report how the knob is set.
I only have one Danfoss. :-) My plans need more, than i can do with the Danfoss.
mhn
Postby TANE » Sat Oct 31, 2009 9:10 pm
I have 4 and will extend that to 10 in the next weeks after replacement of some knobs.
Danfoss works great.
Postby Mversluis » Sat Oct 31, 2009 11:18 pm
I have 5 working within vera , but 1 system is not running proberly.
So i still most found some spare time to chech it out.
Last day i was testing with to controll those from a event from vera and it seems like it works ( not fully tested)
==> code "luup.call_action("urn:upnp-org:serviceId:SwitchPower1","SetTarget",{ newTargetValue="1" },26)"
where 1 is listed ( on ) and 0 would be ( off )
where 26 is listed to the current device nr.
Mversluis
Postby Peter Meuris » Sun Nov 01, 2009 9:13 am
Sorry to bother you again, but this is a newbie question.
By pushing the control button, you can trigger an event on the vera box?
Is this right ?
Peter Meuris
Postby Mversluis » Sun Nov 01, 2009 11:14 am
Hi Peter,
Never tryed this. Normally we set the heater on by pushing on radator , or true a computer.
witch function should it be doing form you;re prospective...?
Mversluis
Postby mhn » Sun Nov 01, 2009 12:01 pm
I haven't tried it, but I think you can set a scene in Vera that trigger an event, when the sun/moon change state. That will happen when you push the button. But it will also happen when it change by a timer.
mhn
Postby TANE » Sun Nov 01, 2009 12:25 pm
@Peter,
That's a good idea also for Homeseer.
example.
Turning number 1 on can also turn number 2 on.
other option turning bathroom on will trigger a delayed event that will turn of after 1 hour.
Postby Peter Meuris » Sun Nov 01, 2009 12:31 pm
Can anybody send me a detailed manual for the DANFOSS device ?
I want to start up the heating (via a zwave thermostat) when someone pushes the control button.
Peter Meuris
Postby EzHome » Sun Nov 01, 2009 9:35 pm
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Peter Meuris</i>
Is this right ?
This is correct, by pushing the button it's status changes and it can be triggert in Vera, now it can execute a scene which changes the other ones in your home.
Here you can find the most complete manual:
http://www.ezhome.nl/downloads/danfoss/ ... _sp_en.pdf
EzHome
Postby johnz » Tue Nov 10, 2009 12:59 pm
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by johnz</i>
<br />Unfortunately, I also seem to have Comap thermostats with a smaller nut than the M30 (...) For those with the same issue: it seems there is an adapter: <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Had to wait quite some time but received them yesterday. They fit [:)] Saves a lot of work.
John
johnz
PreviousNext
Return to Z-Wave Forum
