Danfoss Zwave radiator valve Review [Dutch/English]
Re: Danfoss Zwave radiator valve Review [Dutch/English]
Postby Noel » Sun Jan 03, 2010 9:21 pm
Looks like I need the 28mm versions :-(
Marco. Did you get any info from warmteservice about the connectings rings?
Noel
Postby Mversluis » Sun Jan 03, 2010 10:53 pm
Hi Noel,
When I am before closing time in Lelystad , I will drive by for a cup off coffee.
and will ask the employees for those rings, proberly the forgot it.
Marco
Mversluis
Postby talisman » Mon Jan 04, 2010 9:01 pm
I’m also going to chime in with a few questions :)
Like many here I also have city heating, I have this controlled by a single valve which in turn is controlled by a thermostat in the living room. The living room has in floor heating, and takes a long time to heat up the room, which is no problem, but upstairs I have normal radiators and it gets VERY warm here because the city heating pumps through some extremely hot water and while the living room might take an hour to get to temperature, the upstairs rooms reach it in a much shorter time but stay open since they are also controlled by the livingroom thermostat – closing the radiator valves almost shut does little more than delay the heating for about 10 minutes.
Will the danfoss radiator valves shut off completely via z-wave? Or only manually? I am slightly confused about this since it was mentioned it only does the moon / sun thing via z-wave, changing the temp by half a dozen degrees?
Cheers,
Elco
talisman
Postby r_255 » Thu Jan 07, 2010 3:03 pm
@talisman,
Just a small tip :
To regulate flow distribution you can use the inbus at the foot tvalve ( litt translated from the dutch word voet ventiel ) and open/close the inlet gateway to your radiator. So by closing them a bit it should atleast take longer and the floor get more preasure so it might heat up a bit faster.
This is also use full for those radiators in high rooms that get warm to slow. Just close the others a bit so the presure gets up and the warm water gets at higher places sooner.
Witch also makes me wonder or it does save on the amount of used water.
PS: its hidden behind a cap with (screw thread) you got to open up before you see an inbus.
r_255
Postby talisman » Thu Jan 07, 2010 5:11 pm
Well the in-floor heating unit is located just next to the city heating unit, and has its own pump and regulator etc - this allows you to set the ingoing temperature and outgoing temp and it will circulate the water untill it reaches the outgoing temp - I suppose if I want to heat up the ground floor faster I could just up the outgoing temperature so it pumps through more water ... I just don't know what effect this would have on my bills :)
Though I suppose city heating is charged for the difference in joules between the incoming and outgoing water temp of the city heating unit (i.e. the actual used ammount of energy)
that's all theoretical anyways - I already have the radiator valves closed almost completely, and I don't think the in-floor heating is starved for pressure etc - would closing the voetventiel still make a difference in the radiators getting so incredibly hot?
Cheers,
Elco
talisman
Postby Noel » Wed Feb 10, 2010 12:46 pm
Mversluis wrote:Hi Noel,
Marco
And.. Did you have your cup of coffee already?
Noel
Postby Mversluis » Wed Feb 10, 2010 10:39 pm
Hi Noel,
I am sorry it was so busy last weeks when I arrived at Lelystad the warmteservice are closed ( for a while ).
By coincidence I was working at home today and drived to warmteservice for a chat and coffee.
He will promised me to look first thing in the morning and will come back to me.
So just waith for a litlle while :-)
Keep you informed
Marco
Mversluis
Postby TANE » Wed Feb 10, 2010 10:43 pm
Else I will post your phone number. :D
Postby Mversluis » Wed Feb 10, 2010 10:54 pm
Enver , just aranged that all my call will be forwarded to , guess who .... Enver :P
Mversluis
Postby Noel » Thu Feb 11, 2010 12:05 am
Apparently Honeywell does sell (in my case) M28 to M30 converter rings.
I've been looking for some time now, but till now no luck.
.... Nee, maar daar is wel een verloop voor beschikbaar zodat de M30 kraan gebruikt kan worden.
Deze verloopringen zijn verkrijgbaar bij de plaatselijke dhz zaak of installateurs en is van Honywell...
Noel
Postby Noel » Thu Feb 11, 2010 10:01 am
I think I found it :-)
I need a "Ta adaptor m28 - m30"
cvonderdelen.snelbesteld.nl/cgi-bin/sho ... ct=8614285
But than again.. I could also be wrong.
Noel
Postby Mversluis » Thu Feb 11, 2010 10:48 am
Question raissed by honeywell true warmte service , hope to have some update noon.
If this would be possible we will buy them.
pls be patient.
Marco
Mversluis
Postby Noel » Thu Feb 11, 2010 10:54 am
Thank you Marco!
Now lets wait and see.
Noel
Postby Mversluis » Mon Feb 15, 2010 3:20 pm
So it was not so simple as buying a plug by the Gamma :D
It would be a very strange products and warmteservice ask it by difference suppliers.
Only Honeywell are able to deliver them , but honeywell europe is not familair with this products.
Finallay the can order those rings , just order 1 for testing with danfoss M30. ( delivery time will be 3 weeks or less )
After testing we ( Mood ledlight and Ezhome ) will decid to order some more for selling.
So with a few weeks I can post the photo´s and review.
Marco
Mversluis
Postby Noel » Mon Feb 15, 2010 8:18 pm
Great News!
Do you also need (like me) the M28 to M30 ring?
Noel
PreviousNext
Return to Z-Wave Forum
