Today I've got also my second new Aeon Labs Z-Stick.
1. I have update my homeseer pro to version 2.4.0.1.
2. I have installed the driver from Aeon labs on com 4.
3. In homeseer I can see this under the pulldown menu in menu SETUP-INTERFACES. I make the right choice in this pulldown menu. And save everything. Go to the green button MANAGE and clean first the Z-Stick with ERASE-INTERFACE.
Now you can add new devices on the stick.
4. Now go down with homeseer, otherwise you can get problems if you unplug and homeseer is working.
5. To initiate inclusion-Mode, unplug the Z-Stick from the USB connector and then tap the button. The led will blink slowly.
After taken out the stick, you can setup a network with zwave units.
6. To include a new first Zwave device into the network, simply go to the device with the Z-Stick and press on the button you wish to include. The led on the Z-Stick will blink fast during a network neighbor discovery and stay solid for 3 seconds to indicate successful inclusion.
7. Plug in the Z-Stick in your pc and start homeseer.
8. Go to SETUP-INTERFACES and click on the green button MANAGE.
9. Import devices.
I think this is the hole procedure to get a zwave network in homeseer.
Now I have a small problem: I can't get point 6 on my Z-Stick.
Can anybody tell me, what I can do wrong by point 6?
B.R. Wim [:)] [;)]
Problems with Aeon Labs USB stick and Homeseer
Maybe that device is included into an other network?
If so, exclude it with the exclude fuction and again try to include it.
I hold down the button for approximately 3 seconds. The led will blinking fast.
To remove a zwave device from the network, I go with the Z-Stick to the device and press the button on the device. The led will not stay solid.
I tried again, but nothing is happening.
I tried again to add a device, but nothing is happen.
To make for the first time a network with zwave, you have to do something with the Z-Stick?
Or I forgot something else?
B.R. Wim [:)] [;)]
B.R. Wim [:)] [;)]
