Horstmann HRT4-ZW thermostat
1021
Re: Horstmann HRT4-ZW thermostat
Post by 1021 »
can not import HRT4 and ASR into HS
it looks like I have the devices successfully uploaded to the Z-Stick
but when I try to import it into HomeSeer I get this
any help any idea???
1/31/2012 10:45:49 AM - Warning - Aborting Z-Wave send, taking too long to send command to node 27 waited 6 seconds
1/31/2012 10:45:53 AM - Warning - Unable to send a NULL command to Z-Wave device 27
1/31/2012 10:45:53 AM - Z-Wave Warning - The new node (27) is not a listening device, or it is currently not responding. If this is a listening type device and it is not a generic controller, please make sure it is awake before trying Import/Rescan again.
1/31/2012 10:45:54 AM - Z-Wave - Warning - failed receiving an interface acknowledgement for transmission to node 28 before timeout - the command may not have succeeded.
1/31/2012 10:45:58 AM - Warning - Unable to send a NULL command to Z-Wave device 28
1/31/2012 10:45:58 AM - Z-Wave Warning - The new node (28) is not a listening device, or it is currently not responding. If this is a listening type device and it is not a generic controller, please make sure it is awake before trying Import/Rescan again.
1/31/2012 10:46:00 AM - Z-Wave - Warning - failed receiving an interface acknowledgement for a controller command before timeout - the command may not have succeeded
thanks in advance
1021
Bastiaan
Post by Bastiaan »
Did you use the right order?
Switch first, then the thermostat? Using the L mode?
Did you reset the thermostat to the defaults before you started?
I think you should be a bit more clear in the steps you made so we can understand what and where it goes wrong.
Did you read Maartens blog for the crucial bits and pieces?
http://www.maartendamen.com/2011/05/hor ... hermostat/
Looking at the error it seems you did not keep the Thermostat in L mode while importing from the stick.
In L mode HS can find it, otherwise it goes in sleep mode for minutes.
Bastiaan
1021
Post by 1021 »
Hello and thanks for the replay
I think I used the correct order first ASR than HRT
I used the L mode with the L flashing during the import into HS
What do you mean by "reset the thermostats to the defaults"
I've have read Maartendamen blog to the dot
Thanks for any help
1021
Bastiaan
Post by Bastiaan »
TO make the post complete, here is also the important extra info from Maartens Blog:
http://www.maartendamen.com/2011/06/hor ... open-ends/
1021
Post by 1021 »
Hello
Yes Ive read that blog as well
I will try it all over again over the weekend
By the way is there any alternative in EU to this thermostst
What type of stat do you guys use that works with HomeSeer
and EU gas furnices my needs 230v relay to work
I have Vaillant turbotec pro
Thanks for any advice
1021
Bastiaan
Post by Bastiaan »
I am using the Horstmann to control my floorheating pump (220v).THe switch is just a relay you can use for anything.
Scheduling via Homeseer events works perfect.
Just waiting for HS to get it really supported as a Thermostat.
Dvbit
Post by Dvbit »
Hello
I am new to domotics.
Since this toys are quite expensive I am planning to start with a aeon zwave 2 stick, a switch from fibaro and a thermostat from horstmann
I have a doubt: I see that the thermostat is sold either "standalone" or with a receiver module. do I need thi receiver module or can I just substitute my current traditional thermostat with the hrst?
Further question: if later I plan to introduce danfoss valves on radiators how do this play together with Te thermostat?
Ty in advance for your advice
Zaphod
Post by Zaphod »
Did anyone try the Horstmann HRT4-ZW with the Domotiga software?
uAlex73
Post by uAlex73 »
The open-zwave supports the Hortsmann, but the thermostat functions aren't available yet in DomotiGa (it is on my todo list).
Link:
http://www.domotiga.nl/boards/1/topics/845
Zaphod
Post by Zaphod »
Does anyone know how to set the set point? What z-wave command does it need to get?
Currently I can read the temperature from the thermostat. It is reported in my software, Domotiga. However, I am not able to set the set point, yet.
uAlex73
Post by uAlex73 »
DomotiGa can't do it yet, but you can see the temperature and i think you can do a basic on/off. I will investigate the setpoint option very soon, after i have finished the new OpenZWave wrapper.
davidmit
Post by davidmit »
Hi all, Any News on this?
I've got a HRT4 and would love to run domotiga. So I'd love to know when this will be working.
uAlex73
Post by uAlex73 »
It isn't support yet, but i will try to get the code into DomotiGa this january 2013.
davidmit
Post by davidmit »
That will be great, I look forward to it
uAlex73
Post by uAlex73 »
Anybody here with a Horstmann HRT4-ZW and using DomotiGa? I want to add support to DomotiGa, but i need information (what is detected and how it is shown in open-zwave & the wrapper) and somebody who can test the new code.
Return to “Z-Wave Forum”
