I want to know what type of wallswitches from Jung you would need to use with Fibaro relay and dimmer switches. I have a couple of Fibaro relay and dimmer switches operational. But when I now push my regular Jung wall button it doesn't work. I need to push twice. That's OK to do, but now we have problems that we have lamps with and without fibaro.
I now have the 506 EU from Jung. Could someone please help, because you can choose from a "tipschakelaar" and a "impulsdrukker".
Jung Wallbuttons in combination with fibaro switches
Re: Jung Wallbuttons in combination with fibaro switches
You can look for the Jung 532-4U.
try to change Parameter no. 13 and/or 14 of the Fibaro
- Starting Member
I tried that, but can't get that working. You can't dimm anymore after doing that.Jon Diver wrote:Hi,
I don't know if you guys eventually found a solution, but I'm awaiting my dimmer with jung switch as well.
Can you give an update to this topic?
ELV FHT80b heating system.
