Some time ago i bought two Duwi Dimmers on hashop both are connect to a normal light bulb for now but i would like to save some money on the energy bill. Which lamps are support for the Duwi Dimmers. I know not al types are supported because of the fact that the lamp must use a little current to power the reciever.
One of my dimmers looks to be dieing (HF noise and last 2 days no response on the Z-Wave network) and i will get RMA for it. But i would like to replace lamps and dimmer at once.
Supported
glowbulbs (40-250W)
HV Halogebulbs (40-250W)
Duwi dimmer lampbulb support
Re: Duwi dimmer lampbulb support
I tried today the gu10 LED spots from LedItLight.net .. I can confirm that those don't work with de Duwi dimmer Fuse in the dimmer is blown and one of the LED spots is dead.
On their site they state:
Dimbaar
Deze LED lampen zijn dimbaar met normale dimmers. Worden uw huidige lampen gedimd met een dimmer, dan kun u deze dus zonder problemen vervangen door deze dimbare LED lampen. Uiteraard kunnen deze LED lampen ook gebruikt worden met een normale schakelaar.
That is my fear exactly so for now im just placing 3 x GU10 with 20Watt halogen bulb
