Z-wave curtain (drapper) control
Postby hilgie » Sat Feb 11, 2012 9:24 am
Currently I'm looking into controlling my curtains with zwave. The only fully z wave control I came accriss on the internet are the ones from forest ( http://www.gordijncomfort.nl/bestellen.php).
I'd find this rather expensive.
I also found the ones from Harrison, but this is x10 (should still be able to control through vera) and cists half as much as the the ones from forest.
I'm really interested if anyone else has a more affordable solution.
Cheers Danny
hilgie
Re: Z-wave curtain (drapper) control
Postby freakstar » Sun Feb 12, 2012 9:54 pm
Same here, very interested in nice solutions. Have some touchts to build something myself beceause i don't want to lose my "roedes" (don't know how to call it in English).
freakstar
Postby Phaeton » Mon Feb 13, 2012 7:35 am
I use a cheap electronic curtain rail. Now a days you can find them sometimes on marktplaats/ebay or else in some domoticashops. Its the type where you connect up to four rails of one meter. Its chinese, but in holland they sold it under the brand schadeboo (or something like that) at praxis for some time.
It has a wired remote, which after some testing i replaced with a duwi z-wave curtain switch. This works fine for me.
Phaeton
Re:
Postby hilgie » Mon Feb 13, 2012 12:21 pm
Phaeton wrote:I use a cheap electronic curtain rail. Now a days you can find them sometimes on marktplaats/ebay or else in some domoticashops. Its the type where you connect up to four rails of one meter. Its chinese, but in holland they sold it under the brand schadeboo (or something like that) at praxis for some time.
So, this works fine with veta or hs? Do you actually get a status back in vera if hs? And when you open or close by hand you see this as well in vera or hs?
What were the total costs of this solution?
Cheers,
Danny
hilgie
Postby Phaeton » Mon Feb 13, 2012 1:47 pm
I found a electronic curtainrails on marktplaats (new) for €100,-. The duwi curtain switch was spare, but costs around € 50,-.
If you buy the zwave.me version of the curtain switch the status changes also with manual control. I update my devices in homeseer every 300". This is fine for me.
Phaeton
Postby hilgie » Mon Feb 13, 2012 2:38 pm
Ok, I've found something on the internet: http://www.exp-china.com/html/electric- ... 00_5m.html
It says that it has a 6-pin intergration interface available.
What can I do with this? Put a duwi zwave.me controller on it?
Cheers,
Danny
hilgie
Postby Phaeton » Mon Feb 13, 2012 4:59 pm
I have exactly the same type.
But from a different 'brand' (probably a rebrand).
my type number is cl-200t.
You can find a lot of video's on youtube: http://www.google.nl/search?hl=nl&q=ele ... 80&bih=848
Only difference is this has a RJ45 connection, which should make it easier to connect to the duwi module. My remote was soldered, so I cut the wire ;-)
tonight I'll post some pictures of how I did it.
groeten,
Phaeton
Postby hilgie » Mon Feb 13, 2012 7:05 pm
Phaeton wrote:Only difference is this has a RJ45 connection, which should make it easier to connect to the duwi module. My remote was soldered, so I cut the wire ;-)
Some pics would be nice. Also, could you tell me which zwave.me controller I've to buy for this?
Cheers,
Danny
hilgie
Postby hilgie » Thu Feb 16, 2012 11:20 am
Phaeton,
Any luck with the pics? Still ver curious. Also which zwave.me controller to use.
Cheers,
Danny
hilgie
Postby redcld » Tue Jul 24, 2012 4:22 pm
hilgie wrote:Phaeton,
Cheers,
Danny
I have the same one and trying to make it work with Zwave. Did you have any luck? Did you use thr RJ45 or did you have to open up the motor?
Thanks
redcld
Re: zwave curtain
Postby redcld » Tue Jul 24, 2012 4:34 pm
will any duwi module work?
Is it just a matter of figuring out which wire does what from the rJ45 then splicing them into module?
Thanks.
redcld
Postby Moskus » Sun Aug 26, 2012 7:05 am
Hi RedCld,
have you tried this yet? I'm wondering about cheaper options for blind control too. The china version could be good.
HSPro 2.5.0.60, X10 CM11, Z-wave Aeon Stick2, RFXCOM, Script Connector, BT connector, DI Connector, DooNetwork, HSTouch, Squeezebox plugin, iTach WF2IR & GC-100-6 with UltraGCIR, BLicon, DenonAVR, WebcamXP, Jon00s MaxiBee and Webpage builder
Moskus
Postby Phaeton » Sun Aug 26, 2012 11:16 am
Sorry for the late answer. Let me explain. I just openenend my duwi shutter module to make a pictures of the way I connected it.
This is how I did this:
I openened up the remote. The I found out that every button has it own live wire and there is one neutral wire in the remote. The buttons shortcuts the correspondenting live wire with the neutral wire. This made it easy to use in a shutter module. lengtened the wire from the motor to be able to build the shuttermodule in my wall.
I fixed the module like this:
N = Blue wire = neutral 220 volts
L = Brown wire = Line/live wire 220v
~1 = the live wire (5 or 12 volts, cannot remember) from the remote that correspondents with the opening button
~2 = the live wire from the remote that correspondents with the closing button
com = the neutral from the remote(important, dont use the 220v neutral)
A little more explanation:
The N & L are for feeding the module with power and are in no way connected with the ~1, ~ 2 and com. These are seperated.
Because the buttons give a ' pulse' when you press them, you have to reprogramm the duwi.me module to shorten the time the relay makes contact. You can find an instruction here: http://www.ihomeautomate.eu/2011/10/?lang=nl
This way I can fully open and close my curtains in Homeseer, with the button or just pulling on them. I use the last option the most :D
groeten,
Phaeton
Postby Moskus » Mon Aug 27, 2012 7:59 am
Thanks for the information, Phaeton.
What Z-wave devivce is that?
Moskus
Postby cw-kid » Thu Oct 18, 2012 1:22 pm
Hi Phaeton, thanks for sharing.
I would really like to do the same thing in my living room, please can you confirm which curtain rail you have, CL-800 ? Can anyone else answer my questions?
Looking on the web there are several types of electric curtain rail systems available.
CT-220 This is from Aliexpress I don't know the manufacturers name.
Curtain Call CL-810T
With the CL-810T there is an optional box for connectivity to home automation systems see it here not sure if I would need this box to connect to the Duwi blind control module ?
CL-800 here looks the same system as the CL-810T and also has the option of this home automation connectivity box.
I am assuming this Z-wave.me would be the correct Duwi blind module to use.
I would like central opening curtains I am assuming I only need a single motor for this and not a dual one as shown in this image I think a dual motor setup is for if you have a sheer behind the curtains.
Thanks
EDIT: Long and detailed thread here about electric curtain tracks and Z-wave on the Micasaverde forum.
cw-kid
Next
Return to Z-Wave Forum
