ZME Dual Sensor
Re: ZME Dual Sensor
I think the docu is not correct.
I have contacted CP from ZWE.
There most be another way to correct the problems...
I/O is working fine in Homeseer and Vera
Akatar
Re: ZME Dual Sensor
Post by Akatar »
same thing here:
11-7-2012 20:11:27 - Warning - Z-Wave Multilevel Sensor device Z-Wave Z-Wave Interface Child 37 Sensor Multilevel is missing Sensor Type information - cannot update sensor status.
11-7-2012 20:09:56 - Error - (2) Sensor Multilevel Report for type Relative_Humidity received, but the corresponding device Node ID cannot be found. (2)
it doesn't work
Akatar
Re: ZME Dual Sensor
Post by Akatar »
still no News?
Re: ZME Dual Sensor
When you are also going to use this sensor for tempertuur you need to wait for the new firmware.
Combination of normaal I/O and temperature will not work.
The new firmware will be available soon.
mhn
Re: ZME Dual Sensor
Post by mhn »
Can we firmware upgrade ourself?
Akatar
Re: ZME Dual Sensor
Post by Akatar »
TANE wrote:When you are also going to use this sensor for tempertuur you need to wait for the new firmware.
is it me or does it looks like that domotica is becoming more and more a joke?
duwi makes dimmers/switches, the parts will fall off, but hey no problem, some glue or tape and it will work.
the sensor for temp also not working, but maybe in the next firmware
how can you put a sensor on the market for temp and it's not working?
Re: ZME Dual Sensor
Sorry I'm just the messenger.
Self upgrade is not possible. I have not seen this by any zwave product.
If the module is not doing what you want you can send it back.
I every product there are bugs.
I think they have not tested the product as we want to use it. Alarm an temperature is working fine out of the box
I agree with de Duwi Everlux product line... this not good.
mrtiger
Re: ZME Dual Sensor
Post by mrtiger »
Where can i bay this unit?
Return to “Z-Wave Forum”
