Has somebody experience with the Duwi Z-wave buildin switch for Busch-Jaeger?
I was wondering if the existing wipper(Busch-Jaeger) can be used with this switch or can the wipper of the Duwi be converted to hold the default Bush-Jeager wipper.
Convert Duwi Z-wave build in wipper Bush-Jaeger?
Homeseer 3 Pro on Windows 10 / Zwave
Edwin.
Edwin.
Re: Convert Duwi Z-wave build in wipper Bush-Jaeger?
You will always need to use the BJ paddle from Duwi.
You have to push the Duwi button. This can't be done by the normal BJ
Frame is the same..
Color problem can be fixed see my blog
http://blog.tane.nl/duwi-busch-jaeger-in-kleur-wit/
Frame is the same..
