Dimming 12V leds...
Dimming 12V leds...
Is it possible? And what trafonsformer or anything else do I need to make it possible with a Fibaro FGD-211?
HSPro 2.5.0.60, X10 CM11, Z-wave Aeon Stick2, RFXCOM, Script Connector, BT connector, DI Connector, DooNetwork, HSTouch, Squeezebox plugin, iTach WF2IR & GC-100-6 with UltraGCIR, BLicon, DenonAVR, WebcamXP, Jon00s MaxiBee and Webpage builder
Re: Dimming 12V leds...
Dimming 12V leds is often done by switching in more or fewer leds in parallel.
Adjusting the voltage or using PWM will do also but the results may vary.
Okay, I will have to try that. Perhaps it will be a "manual" dim with just on/off controlled from HomeSeer.
