Thermostats...?
Thermostats...?
Are there no thermostats for Europe that works with HomeSeer?
HSPro 2.5.0.60, X10 CM11, Z-wave Aeon Stick2, RFXCOM, Script Connector, BT connector, DI Connector, DooNetwork, HSTouch, Squeezebox plugin, iTach WF2IR & GC-100-6 with UltraGCIR, BLicon, DenonAVR, WebcamXP, Jon00s MaxiBee and Webpage builder
Re: Thermostats...?
As it says in the article, there are several posts that claim that it doesn't work with HomeSeer. Have you tried it yourself?
Re: Thermostats...?
i use proliphix nt 10 and nt20 , but they arent made anymore , proliphix has went his strategy to big buildings climate control, the homeuser is not interesting anymore just like plugwise.
there are a lot of new online thermostats , but the disadvantage , in my opnion is it is al cloud based, not for a stand alone system like homeseer on you computer at home.
The trend is a tablet at home and servers in the cloud.
Re: Thermostats...?
... yes, I've seen this too. And that's all good and well until your internet connection drops and you can't turn of the living room lights anymore.labium wrote:The trend is a tablet at home and servers in the cloud.
(The same reason why I don't believe in web storage only, like the old Skydrive was. You NEED a local copy of your files.)
I prefer to have my home control where it belongs: At home.
Re: Thermostats...?
I posted the link cause I knew Maarten had a ZWave thermostat; sorry I didn't read his whole post.Moskus wrote:Have you tried it yourself?
No I didn't try it, I don't use Homeseer.
Re: Thermostats...?
I figured as much, but thanks anyway.Digit wrote:I posted the link cause I knew Maarten had a ZWave thermostat; sorry I didn't read his whole post.Moskus wrote:Have you tried it yourself?
According to my reading it should work somehow til HomeSeer.
Re: Thermostats...?
I am using the Horstmann with Homeseer. Two things:
The HS plugin did not work very well but they promised to fix it a while ago. Haven't had time to check the latest version but I am sceptic.
There is no timer system in the HRT4
I am using some events that directly control the thermostat, setting morning, evening and night temps. That worked well last winter. I can also see the temp and settings on the HS touch screens although that has a huge lag and is not always reliable.
See: http://www.domoticaforum.eu/viewtopic.php?f=26&t=7090
Bastiaan
Bastiaan
Re: Thermostats...?
I have been lokking for this too, but havent found something that i can use.
