I wondered if it's possible to use the fibaro bypass in combination with the duwi dimmer (non-z-wave) i have in my house. Since i want to start replacing my 50w halogen lamps with dimming 230v gu10 led lighting.
Or is there a alternative (cheaper? )
Ability to use Fibaro bypass for duwi dimmer
groeten,
Re: Ability to use Fibaro bypass for duwi dimmer
The bypass is not much more than a capacitor which you install parallel to the load (light).
Okay, I googled capasitor (kind of understand now). But can you use it in combination with a Duwi Dimmer?
groeten,
