Z-Wave pull switch
raymonvdm
Z-Wave pull switch
Post by raymonvdm »
In the bathroom the light is switched on/off using a Pull Switch. The rope of the current pull switch is getting bad and i would like to replace the pull switch before it btreak. But to make things more easy i also would like to move on to a z-wave enabled version.
What is the best option for this. I already bought a Bush-Jaeger pull switch but this is a on/off switch not a puls switch.
https://www.elektroschakelmateriaal.nl/ ... -4599.html
uAlex73
Re: Z-Wave pull switch
Post by uAlex73 »
Only thing i can quickly think of, is to put a Fibaro FGS-211 behind it.
jrkalf
Post by jrkalf »
Not sure if this is the best solution, but perhaps the FIBARO Door/Window Sensor?
It has a 2 wire input part. I'm not sure if it's only supposed to be used for pulse or a simple alarm trigger: if connected, then on, if disconnected then off type.
See section two of their website page about this: http://www.fibaro.com/en/the-fibaro-sys ... dow-sensor
ELV FHT80b heating system.
Return to “Z-Wave Forum”
