Z-Wave and Jee Node RFM12B interoperability / 868MHz
solha
Post by solha »
Does anyone know if Z-Wave and Jee Nodes using RFM12B both on the 868 MHz frequency range can co-exist, ie, transmitting at the same time without jamming each other comms? I know that Z-Wave in Europe uses 868.4 MHz but don't know if that's the exact frequency used by the RFM12B on Jee Nodes.
Thanks in advance & Regards.
wwolkers
Re: Z-Wave and Jee Node RFM12B interoperability / 868MHz
Post by wwolkers »
Z-Wave in europe uses the 868.42 MHz SRD Band.
JeeNodes are configurable, but by default use 868.00 MHz if I'm not mistaking.
So this should not be a problem at all.
Also, both devices adhere to the 1% specification, as in that they only broadcast at most 1% of the time, so collisions should be rare.
Return to “Z-Wave Forum”
