motor blind control and procents dimlevel not working
sjnelle
Post by sjnelle »
I have a zwave.me motor blind control. I want to control it with dimlevel procents so when I set 50% the blind goes 50% down or up.
But when I send the values the heigt of blind is always different, mostly after I use full close or open.
I tried different software, domotiga,homegenie, homeseer.
I played with the full open and close parameters but I did not get It good.
I think I have to configure it from a good starting point but I don't know how and its driving me crazy.
Does anyone have some tips for me?
uAlex73
Re: motor blind control and procents dimlevel not working
Post by uAlex73 »
Did you try to calibrate it? This seems to be needed for roller blinds (other similar Fibaro device manual states that):
http://www.indome.ee/wp-content/uploads ... 10-ENG.pdf
I myself just ignore the percentage/dim, i am only interested in open or close.
sjnelle
Post by sjnelle »
there is nothing in the manual of the duwi for calibrating :( only the full open en close time paramters
xanhoera
Post by xanhoera »
For the original duwi devices managing the operating times was possible: http://www.ihomeautomate.eu/2011/10/22/ ... nd-insert/
jrkalf
Post by jrkalf »
Sorry to perhaps state the obvious, but perhaps you've already taken this into account.
When you're using blinds for sunscreens etc keep in mind that the roll-down is faster then the Roll-up phase. (at least, it' is in my case). So when working with percentages to manage an analog motor, you'l probably end up on different levels then you're expecting it would be.
ELV FHT80b heating system.
Return to “Z-Wave Forum”
