TZ66-S zwave firmware update
zyx
Post by zyx »
I'm the owner of more then a few TKB HOME TZ66S wall switches.
While configuring these switches, i noticed that i have a variety of firmware versions running on my switches.
The main difference in these versions is that the older generation only switches the connected load while the newer version can also separately switch external devices using double or triple tapping of the switch.
In my case i would very much like to use the double tapping functionality.
Does anyone know if the firmware on these switches is field upgradable?
Thanks!
Zyx
raymonvdm
Re: TZ66-S zwave firmware update
Post by raymonvdm »
It does not look like it
http://www.tkbhome.com/?cn-p-d-110.html
Maybe you can contact the reseller to swap the units (as he can maybe upgrade then just like zwave.me firmware ?)
Return to “Z-Wave Forum”
